**Brake Light Question** - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2003, 12:46 AM   #1 (permalink)
4A-GE's Avatar
View 4A-GE's Photo Gallery
Lightbulb **Brake Light Question**
today.. i install a long LED brake light to my Camry from a DelSol... personaly...i think it looks really good!
... but after i install everything... went for a test drive.. the 'Light' warning singal lights up... it's pretty annoying... so can anyone help me get that warning light off? thx
here are some photos...
4A-GE is offline   Reply With Quote
Old 12-02-2003, 12:47 AM   #2 (permalink)
4A-GE's Avatar
close up
Old 12-02-2003, 12:48 AM   #3 (permalink)
4A-GE's Avatar
warning light
Old 12-02-2003, 01:11 AM   #4 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
cant help, but it looks good...
try checking if you forgot to hook up some wires, or one is messed up...
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 12-02-2003, 12:51 PM   #5 (permalink)
[ Crazy - Dog ]
View TOM'S CAMRY's Photo Gallery
Check the wires!
Calvin
94" Gen3
4 pieces Clear bumber lens, K&N Drop in Intake, PIAA 4150K Headlights
ISImpression.net
TOM'S CAMRY is offline   Reply With Quote
Old 12-02-2003, 01:25 PM   #6 (permalink)
View Tubbyc's Photo Gallery
take out the bulb for the warning light
Tubbyc is offline   Reply With Quote
Old 12-02-2003, 03:04 PM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
LED's draw less current than a light bulb.
So its thinking that your 3rd brake light is out (the light on the dash).
"Skoolin' the unlearned!"
Old 12-02-2003, 03:11 PM   #8 (permalink)
4A-GE's Avatar
but the LED lights are 12.5volts... the original is 12volts... does that make any problems as well?
....thx
Old 12-02-2003, 03:31 PM   #9 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
actually it because the LEDs dont act like a ordinary light bulb so the resistance of that set of LEDs is abnormal to what it would be with a lightbulb........
Am i confusing yoU? if so don't worry about it. it should cause a problem, other than u not knowing when one of ur other bulbs are gone.
- Vince
VVT-i Owns is offline   Reply With Quote
Old 12-02-2003, 03:48 PM   #10 (permalink)
View DIRTBIKEZ's Photo Gallery
Does'nt he need to determine the difference in wattages between both LEDs and incadecent bulbs then wire in a resistor in series?
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
DIRTBIKEZ is offline   Reply With Quote
Old 12-02-2003, 04:49 PM   #11 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
I think something to that effect should work.
Brandon
arcasmachineracing is offline   Reply With Quote
Old 12-02-2003, 05:56 PM   #12 (permalink)
限界域への独走。
View mobes's Photo Gallery
You'd want to wire the resistor in parallel (not series), otherwise you'd have some very dim LED's.
mobes is offline   Reply With Quote
Old 12-02-2003, 06:51 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
A resistor would work.
LED's draw about 20mA each. So total # of LED's x 20mA = total current draw.
P = I x E
P = power in watts
I = current
E = voltage
Example: you have 20 led's x 20mA = .4 amp
P = .4 x 12
P = 4.8 watts
1156 bulb = 27 watts
27 - 4.8 = 22.2 watts
P = (I x I) x R
P = power in watts
I = current
R= resistance
22.2 = (.4 x .4) x R
22.2 = .16 x R
R = 22.2 / .16
R = 138.75
So for my example you need around a 140 ohm 25W resistor.
Old 12-02-2003, 07:50 PM   #14 (permalink)
4A-GE's Avatar
P = I x E
P = power in watts
I = current
E = voltage
P = .4 x 12
P = 4.8 watts
P = (I x I) x R
P = power in watts
I = current
R= resistance
22.2 = .16 x R
R = 22.2 / .16
R = 138.75
math!
thx 88LE
let me check if i can get a 25W resistor....
Old 12-03-2003, 06:27 AM   #15 (permalink)
My car looks good wet
View 90CamryDx3SFE's Photo Gallery
Same thing happened in my SV21 when I put my wing on it. Except this fried the yellow boxin the back. Shop "repaired" it by soldering up a connection, however everytiumeI click my brakes with the headlights on, the "lights" IL will flash on for a second.
Actually, lastnight my headlights were going off for a second everytime I hit the brakes for a few times. Then the lights light would flicker while the brakes were on, asif it were showign a short beginning...
How can I go into the yellow box, and perhaps sure up this soldered connection a bit more? or eliminate the damn light.
First Gen 2 with a Flowmaster
Shot transmission, but it's all good.
90CamryDx3SFE is offline   Reply With Quote
