96 Camry Transmission Shifter is stuck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2008, 08:01 PM   #1 (permalink)
View DennisMc's Photo Gallery
My daughter's 96 Camry is stuck in park. The button will not push in to take it out of park and we must use the override. Does anybody have any idea what might cause this?
DennisMc is offline   Reply With Quote
Old 08-11-2008, 06:01 AM   #2 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Check the brake light switch.
DFBonnett is offline   Reply With Quote
Old 08-12-2008, 11:24 AM   #3 (permalink)
Update of Stuck Shifter
Thanks for the tip. It was not the switch but in that circuit. A friend of a friend is was a Toyota Technician. He suggested it might be a short in the stop light circuit that blew the fuse. Seems that the design of the harness takes the wiring into the trunk via the hinge on the driver's side. He suggested looking there, apparently a pretty common problem. I looked and found 3 wires in the hinge area that had bare spots on them. It looks like the repeated bending of the wires has caused a brittleness and the insulation had fallen off. I taped them up, changed the fuse and problem solved.
