Owner of Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-17-2008, 04:16 PM   #1 (permalink)
View StanZet's Photo Gallery
USA Owner of Camry
Toyota Camry- 1998 - car engine is cranking after turning key to "OFF". What is the reason?
StanZet is offline   Reply With Quote
Old 08-24-2008, 12:19 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
You might want to repost this in the Gen 3/4 section.
Initial thoughts are that you have a short. For some reason I seem to focus on the ignition switch but it could be at the starter or relay too. How sure are you that the starter disengages when the engine starts?
Kep
Old 08-24-2008, 03:36 PM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It's usually the starter. You'll have to check it to be sure though.
2006 Camry LE Special Edition
Old 09-04-2008, 05:46 AM   #4 (permalink)
View solidg's Photo Gallery
maybe the prior owner had a remote start. This can cause havic. Id have the remote start removed.
solidg is offline   Reply With Quote
