MSD Ignition ?'s - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2003, 01:20 PM   #1 (permalink)
www.SouthCheeze.com
View Jokeplayer's Photo Gallery
MSD Ignition ?'s
For those of you who have run an MSD box in your cars, I have three short questions for you.
1) Which box did you use?
2) Did you use your stock distributor? (my '93 still has a distributor with an external coil.)
3) Which coil did you choose?
Thanks,
Steve
Steve
Steve@SouthCheeze.com
www.SouthCheeze.com
Jokeplayer is offline   Reply With Quote
Old 12-04-2003, 02:17 PM   #2 (permalink)
Eric-Camry's Avatar
View Eric-Camry's Photo Gallery
you don't have to get a new coil and you can use the stock distributor a lot of times. It depends on what you are trying to do. I don't have one, but have assisted in installed 3 of them, and in all cases the box was the only thing added. Forgot the model number but they go for about $200-220 at most auto parts stores. You can find them online for 10-20 less and pay 10-20 for shipping, so everything balences out most of the time.
I have AD... ...HEY A CARE BEAR!
Eric-Camry is offline   Reply With Quote
Old 12-04-2003, 02:48 PM   #3 (permalink)
www.SouthCheeze.com
I've helped install a 6AL before, I was thinking of just getting the 6A, i don't really need the rev-limit and I can always add it later. I'll keep the stock distributor and coil for now - I would like to upgrade to an MSD higher output coil one of these days.
Thanks,
Steve
Steve
www.SouthCheeze.com
Old 12-04-2003, 03:22 PM   #4 (permalink)
Eric-Camry's Avatar
thats the easiest and best thing to do for starters, just add to it later
have you gotten sparked by one? that stings a good bit <-- at myself
Old 12-04-2003, 03:53 PM   #5 (permalink)
www.SouthCheeze.com
I haven't been shocked by a MSD equipped car..... but I've been shocked more than enough times by my Camaro while adjusting the timing .
Steve
www.SouthCheeze.com
Old 12-04-2003, 06:20 PM   #6 (permalink)
Eric-Camry's Avatar
if I am working on something, computers, cars, etc. I am not really working until I am shocked or bleeding
Old 12-04-2003, 06:42 PM   #7 (permalink)
www.SouthCheeze.com
Fair enough.
Were those other cars you had installed MSD boxes in, were they camry's?
Steve
www.SouthCheeze.com
Old 12-05-2003, 12:01 AM   #8 (permalink)
Eric-Camry's Avatar
my buddy matt's 240 and another friends 240. Both s13s.
Old 12-05-2003, 01:19 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: MSD Ignition ?'s
Thanks,
Steve
1. 6A
2. Yes
3. MSD Blaster SS
You also need a tach adapter (MSD 8910-HEI).
"Skoolin' the unlearned!"
Old 12-05-2003, 02:08 AM   #10 (permalink)
www.SouthCheeze.com
Sweet! Thanks, that is exactly the info I need.
Steve
Steve
www.SouthCheeze.com
Old 12-05-2003, 01:49 PM   #11 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
1. msd SCI
2. had to custom the distributor to use an external coil
3. msd blaster SS coil
4. also needed is a tach adapter for a toyota otherwise ur car will stall forgot the part number i think its 895 hei(?)
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 12-06-2003, 08:55 PM   #12 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
I find the MSD the most worthwhile upgrade is the soft touch ignition rev limiter... If you decide to go with the MSD 6-series, always go for the 6AL. You cannot upgrade it later unless you purchase an entirely new 6-AL box.
The better spark in most cases will not offer any significant power increase unless you are boosted, or fitted with higher compression pistons. I would get the MSD jsut because it has nice rev limiter and it saves your engine from damage if you happen to constantly bang on the rev limiter during a misshift, etc...
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
