I had the exact same problem with my Lexus ES300, It is your valve stem seals, when you let it sit overnight the oil leaks past the seals and down your valve guide and when you first start the car the oil gets sucked down into the combustion chamber and it gets burnt, you want to get it fixed asap, because it will cause major carbon buildup on your intake and exhaust valves and foul your plugs out as well from that oil being burnt over time. It will only get worse with time and miles, on your car it is very inexpensive to the valve job. It will cost you around $500-600.00 for a valve stem seal job and I would get a fuel injector cleaning done and get your plugs replaced while you are at it to clean up the carbon that was left behind. I paid $1300 for my valve stem seal job, because mine is the V6 more valves means more seals. I would definetly get it done here pretty soon as you will notice better gas mileage and no more oil burning.
Good Luck
<font size=-1>[ This Message was edited by: erfan on 2002-03-01 12:04 ]</font>
