parking lights problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2008, 12:52 PM   #1 (permalink)
View zmsaad's Photo Gallery
This is a challenging one. I have a 99 camry with auto light system. The parking and dash lights stopped working when you use the switch. At night, all the lights come on automatically. Checked the switch, fuses, and relays (the ones I could see in the engine compartment), and all are OK. Car failed inspection and I do not know what to do.
zmsaad is offline   Reply With Quote
Old 09-03-2008, 01:09 PM   #2 (permalink)
just a nobody
Check the fuses inside the car, I think it is the tail light fuse that feeds your parking lights. Fuse block should be somewhere on the driver's side underneath the dash.
N.E.O.
Old 09-03-2008, 01:24 PM   #3 (permalink)
yes i checked all the fuses and they are in a working order. As i mentioned, all the lights come on at night No problems at all
Old 09-03-2008, 01:41 PM   #4 (permalink)
just a nobody
I misunderstood you when you said only the ones you can see in the engine compartment, probably just the relays.
Possibly the light switch or the auto-light control computer, which I believe is behind the glove box; unless the wiring is open somewhere, maybe in the steering column. Probably have to get a wiring diagram to trace it out.
N.E.O.
Old 09-03-2008, 05:05 PM   #5 (permalink)
Yes, I checked the switch, I have also a 2000 camry, I swaped the light switch and no change
Old 09-03-2008, 05:22 PM   #6 (permalink)
just a nobody
Time for a wiring diagram to trace the circuit and locate the cause.
For short term, you can cover the sensor on top of the dash to trig the system to turn on the lights; of course, it will be on all the time, unless you switch it off.
N.E.O.
