It was real easy to disconnect on my 03 Celica(with help from newcelica.com), guess nobody knows how? Im going to start cutting wires till the dinging stops! weeeeeeeeee
i think it works on a open cercut,all you have to do is find the wires,and cut them if the beeping starts that is a open cercut just crimp the wires together,if it dosent start just cap them off so they dont ground out,you might be abule to pull the fuse but find out what else will be stoped by pulling it, good luck
Anyway, you might have a problem if you disconect the bell as it's probably hooked up to the alarm...you might actually be bypassing any type of door security.
You could try removing that spring thingy by the door jamb and closing the circuit so that even if the door is open, the circuit will still be closed. That way you can drive with your door open, weeeeeeeeeeeeeee.
I disconnected a plug near my ignition switch on my 03 Celi GTS, still had the alarm, not sure how to remove the plastic around the column on the Camry? I hear ringing noises when I sleep. HELP! weeeeeeeee
