anyone know how to time a 3sfe engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2008, 10:58 PM   #1 (permalink)
View mister_two's Photo Gallery
i have one in my mr2 from a camry i need to know how to get it timeed correctly to get it running any of you guys know how to. Thank you!
mister_two is offline   Reply With Quote
Old 09-20-2008, 12:16 AM   #2 (permalink)
just a nobody
Time what correctly? Timing belt? Distributor? Intake and exhaust cam? What year Camry engine?
N.E.O.
Old 09-21-2008, 09:50 AM   #3 (permalink)
View drugal's Photo Gallery
If you mean with just a timing light. then:
Start the engine, and let it warm up. Jumper TE1 and E1 at the TCCS check connector. Your idle should increase to 1000-1300. Loosen the distributor, and rotate it as needed until you reach 10 degrees BTDC. Tighten the distributor and remove the jumper.
What year Camry did the engine come from? The 87 and some 88 models have different sensors and injectors, so you need matching wiring/accessories/ecu, etc
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
drugal is offline   Reply With Quote
