Help Battery !! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2002, 09:08 PM   #1 (permalink)
View 98Toyozip's Photo Gallery
hi Guys !
I am going to buy battery for my
98" Toyota Camry tomorrow.
I need some recommendations!!
I have 2 12" Subs & 2 high Power Amps installed so which is the best bet .
Thanks !!
<font size=-1>[ This Message was edited by: 98toyozip on 2002-03-02 22:09 ]</font>
98Toyozip is offline   Reply With Quote
Old 03-02-2002, 09:14 PM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700165
iTrader Score: 6 reviews
View EKam's Photo Gallery
Optima Yellow Top.
EKam is online now   Reply With Quote
Old 03-02-2002, 09:30 PM   #3 (permalink)
View speedemn's Photo Gallery
Another one to consider is Interstate. Basil put one in my car.
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
Old 03-02-2002, 10:47 PM   #4 (permalink)
RUN WHAT YOU BRUNG
View 92CAMRYGTS's Photo Gallery
get the biggest battery with the most cold cranking amps that you can fit under your hood.
92CAMRYGTS is offline   Reply With Quote
Old 03-03-2002, 01:09 AM   #5 (permalink)
Luc
View Luc's Photo Gallery
On 2002-03-02 22:08, 98Toyozip wrote:
hi Guys !
98&quot; Toyota Camry tomorrow.
I have 2 12&quot; Subs &amp; 2 high Power Amps installed so which is the best bet .
Thanks !!
Well, if you plan on running your stereo with the car off, then Optima yellow top is what I recommend. Otherwise, just get a 1F capacitor if you have a 1000-watt-capable amp. However, for the yellow top or red top, the OEM battery terminals will NOT reach the top posts. I think the orange top has reverse leads on the side posts (GM), so you can reverse the battery and still use the wires.
I have a yellow top in my '98 and I had to rewire all the power and ground. There are two grounds, one under the battery tray, and one to the engine block. There are two powers also, one to the starter directly, and one to the fuse box. The one in the fuse was a big PAIN to get to since I had to trace through the bundles.
If you get an Optima, make sure you get the plate to elevate the battery, so that it will be same stock height, and still use the factory tie down. Here are some pictures.
http://www.imagestation.com/album/pictures.html?id=4292011885
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 03-03-2002, 01:07 PM   #6 (permalink)
Thanks guys!
How is Diehard battery ?
I will get 1 Farad capacitor for the Amps .
Old 03-03-2002, 03:29 PM   #7 (permalink)
Luc
On 2002-03-03 14:07, 98Toyozip wrote:
Thanks guys!
Diehard batteries are pretty good, though its CCA isn't as large as the Optimas. But you can easily get a Diehard Gold for around $80 with the trade-in. BTW, don't let them charge you $8 for the exchange labor. You can drive your car there, park it, remove the old one, take it in, and exchange it. That's what I did for my friend's Gen3 before. I believe the battery terminals are held down by 10mm nuts on the side. Just make sure you disconnect the negative post first.
Luc
Old 03-03-2002, 06:58 PM   #8 (permalink)
I went to Sears auto center Today
&amp; the manager told me that total will be around $90 Installed without trade-in.
I will do that tomorrow.
Thanks guys for the guideance.
