3SFE Gear Box Upgrade - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2003, 09:45 PM   #1 (permalink)
almc2242's Avatar
View almc2242's Photo Gallery
I have a Camry [SXV10] with the 3SFE engine. Does anyone know if this 5 speed can be upgraded? Beefer gears and even change ratios'?
almc2242 is offline   Reply With Quote
Old 12-14-2003, 12:28 AM   #2 (permalink)
View crazy_camry's Photo Gallery
the gearbox from the 3s-ge celica or MR2? AFAIK these have better gearing and is stronger. do a search for more info.
crazy_camry is offline   Reply With Quote
Old 12-14-2003, 01:28 AM   #3 (permalink)
View Deep's Photo Gallery
That or the E153 from a Gen 3/4 V6 Camry or SW20 MR2.
Deep is offline   Reply With Quote
Old 12-14-2003, 09:03 AM   #4 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Guys look at his chassis code I beleive he has an all trac camry which means those trannys you said wont work since he needs an all trac tranny. However in that case what you can swap in is the all trac celica tranny. The ST205 is the best one you can get and it is a direct bolt in. Of course you can still put in the ST185 or ST165 but I wouldn't really suggest the ST165 since it isn't much different from yours. The ST185's is a little different with a larger finaly drive gear. Really what you should do if you want to keep the camry body is just get a whole all trac celica drivetrain from the engine the tranny and the rear end. All of it is a direct bolt in and you will have a much powerful car with that.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 12-14-2003, 09:13 AM   #5 (permalink)
My car looks good wet
View 90CamryDx3SFE's Photo Gallery
Are the motors in All-tracs mounted differently as opposed to the motors in the normal FWD cars?
First Gen 2 with a Flowmaster
Shot transmission, but it's all good.
90CamryDx3SFE is offline   Reply With Quote
Old 12-14-2003, 09:16 AM   #6 (permalink)
SCCA Tech Services
No they are mounted the same as FWD cars.
Brian Harmer
Old 12-15-2003, 10:17 AM   #7 (permalink)
almc2242's Avatar
If you were to Turbocharge the 3SFE engine, with lets say a very streetable 6 PSI. Which would be the ideal Gear Box for it?
Old 12-15-2003, 11:09 AM   #8 (permalink)
SCCA Tech Services
If you are going to turbocharge it then just keep the tranny you have in the car now. Especially with 6 psi you aren't going to be testing the limits of that tranny yet.
Brian Harmer
