1998 Camry Brake Pedal Vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2008, 12:20 AM   #1 (permalink)
View Weez1's Photo Gallery
Hi. I have a 98 Camry with a brake problem. When applying the brakes a vibration is felt in the pedal & entire car. It seems the harder the pedal is pushed the worse the vibration. At first I thought the front rotors where warped. The other day I decided to try slightly pulling on the emergency brake while driving. The same vibration could be felt. Is it possible the rear drums are out of round/warped? In the past on any other vehicle I've owned, this type of vibration ended up being warped front rotors but I think this time the problem is coming from the rear. Any advice would help. Thanks
Weez1 is offline   Reply With Quote
Old 10-09-2008, 01:30 AM   #2 (permalink)
just a nobody
Like rotors, drums can be out of round too. And like rotors, drums can also be machined to correct out of round concern. When front rotors are warped, sometimes you can also feel it through the steering wheel when braking. There are tools available that can check the drums for out of round.
N.E.O.
Old 10-09-2008, 09:25 AM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $351453
View BMR's Photo Gallery
Weez1, do you have drum or disk brakes on the rear? If you have disks, the E-brake has separate pads; it's basically a small drum brake sitting inside the disk. If you have drums, then NEO is spot-on. If you have disks, it might be a bad wheel bearing causing the pulsing. That's what it was for me. Here's a link to my DIY thread to replace the bearing... Link
BMR is online now   Reply With Quote
Old 10-09-2008, 10:26 PM   #4 (permalink)
Thanks for the info. I haven't physically checked the rear brakes yet but I think they're drums (1998 Camry CE 4 cyl). I do not have any vibration during normal driving but only while braking (also when pulling on the emergency brake when moving at regular speeds) - that's why I'm pretty sure the problem is coming from the back.
Old 10-11-2008, 02:22 PM   #5 (permalink)
BAM! It's SPAM!!!
prjkt_c4mry's Avatar
View prjkt_c4mry's Photo Gallery
Because you are a 4 cylinder, you should have drums on your rear. Rear disc brakes only came on the V6.
'99 Camry XLE V6
"Sex should be like a riced Civic; Slow, obscene, and loud enough for the neighbors to hear."
prjkt_c4mry is offline   Reply With Quote
Old 10-11-2008, 05:20 PM   #6 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
I'm not sure how it was for the '98 models, but on the '92's, if you got ABS brakes you got disks on the rear regardless of which engine.
Old 10-11-2008, 09:29 PM   #7 (permalink)
Gameroom cash: $304355
The 98's were definitely rear drums on the 4 cylinder models, with or without ABS. The V6's got 4 wheel discs.
What the original poster is describing definitely sounds like an out of round drum.
Mike
Old 10-18-2008, 09:46 AM   #8 (permalink)
I did a brake job on the rear end. Replaced the drums & shoes with jobber parts. The vibration is gone so I'd have to assume the old drums where out of round. I'm starting to wonder if the savings on the jobber stuff was worth it. Even though the old brakes vibrated when applied, they worked really well (I could lock up the rear tires while driving just by pulling on the emergency brake). Now, there's no way I can do that. The hand brake does engage and prevent the car from moving while parked but it doesn't grab like the old brakes. i figure it must be because the material used in the cheaper jobbers isn't as good as OEM shoes.
Old 10-18-2008, 10:54 AM   #9 (permalink)
just a nobody
There are many factors that would affect brake performance, amount them is the materials being used for construction; however, new brakes do require a little bit of break-in period before they are fully effective. So maybe try it again after some miles and see if they perform better.
N.E.O.
Old 10-18-2008, 12:56 PM   #10 (permalink)
You may also have to manually adjust the new rear shoes a bit closer to the drum.
Mike
Old 09-29-2009, 05:05 PM   #11 (permalink)
View Yanpapa's Photo Gallery
Mike
I've just replaced rear brake shoes and used a brand new drums for my 97 Camry and when I brake and slows down to 10 - 15 mph, it vibrate or pulsate. I'm thinking may be I need to adjust my shoes but when you place a new drum, what kind of resistance are you looking for? I was able to spin a drum with a bit of resistance but is this close enough?
Or am I looking at other problems?
Thanks.
97 Camry LE 4 cyl. 5S-FE 160K miles
10 Corolla LE 15K miles
Yanpapa is offline   Reply With Quote
Old 10-02-2009, 08:02 AM   #12 (permalink)
"I've just replaced rear brake shoes and used a brand new drums for my 97 Camry and when I brake and slows down to 10 - 15 mph, it vibrate or pulsate."
I had that happen once, years ago (in the middle of winter here) when I let someone else do the rear drum brakes on my 86 Camry. One of the brand new rear drums they used was out of round, so it can happen.
As far as resistance, a bit of resistance seems about right. If the pedal heitght seems too low, than they need to be adjusted a bit tighter. I could always tell when it was time for adjustment by the pedal height on my 98 Camry.
Mike
Old 10-02-2009, 12:06 PM   #13 (permalink)
Yes, Once I have re-surfaced drums, vibration has gone and brake is working just fine. However now I have small clicking sound comming from left drum when I brake and slowdown to about 5-10 MPH.
I've greased with high-temp. grease(silver color) at contact points and adjuster tread but I can't fugure this out. May be it'll go away once pads are braking in.
Old 10-02-2009, 12:10 PM   #14 (permalink)
Mike, Thanks for your suggestion on other tread. I'll re-check connection points. and re-grease it.
