AC Cooling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2008, 11:10 PM   #1 (permalink)
View MikeyboyNJ's Photo Gallery
AC Cooling
The AC on my 1995 Camry stops blowing cool air after driving for 30 minutes. I already added some freon but still no good. It blows real cold air in the beginning of the drive but not after 30 minutes. On a warmer day, the cool air only lasts around 15 minutes. What's wrong?
One of my friends told me it's the expansion valve but I dont know. Please help.
MikeyboyNJ is offline   Reply With Quote
Old 10-22-2008, 12:03 AM   #2 (permalink)
just a nobody
You will need a A/C manifold to check the pressure to see if it is indeed the expansion valve. The symptoms sound like it is but the pressure will tell you for sure.
N.E.O.
Old 10-29-2008, 04:17 PM   #3 (permalink)
View davemac2's Photo Gallery
when it stops coolng again, go open your hood and check to see if your rad fan is turning full speed. It may be on its way out.
dave mc
davemac2 is offline   Reply With Quote
Old 11-05-2008, 11:41 AM   #4 (permalink)
View ChaneyTsai's Photo Gallery
Check fan first. It should be running when compressor is on.
Does it blow cool air again if you turn A/C off, wait for a while and turn back on?
2001 Camry XLE, TRD Supercharger, Jim's fuel mod, Eibach Pro Kit, Tokiko struts, Hayden ATF cooler, NGK Irdium spark plugs
ChaneyTsai is offline   Reply With Quote
Old 11-05-2008, 11:48 AM   #5 (permalink)
It would have to be off for a long period of time but I am not in the car long enough to know that. What I do know is that when it stops working and I park my car and not use it again for a few hours, the AC works again when I turn it back on again after a few hours.
Old 11-05-2008, 05:06 PM   #6 (permalink)
If fan is working and freon is enough(check sight glass) then it might be expansion valve is frozen or clogged by moisture or dirt in system. You need manifold gauge to check the pressure to determine. Either case you have to recover freon, open up the system, flush if there is dirt, replace dryer and then recharge freon.
