Tires for 16" Rims - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-17-2003, 11:17 PM   #1 (permalink)
There's a post button?
View Yanahdi's Photo Gallery
Tires for 16" Rims
Just got ahold of some 16" rims.
I've got the TRD Lowering kit (Eibachs/Bilsteins) and I need to know what size will fill out the fender gap the best.
I'm considering a 225/45 size tire.
Can you guys give me any input if this tire size will fill out well for 16" or should I try a larger sidewall?
Thanks in advance.
BTW I'm currently running 205/65/15 size tires on 15" black steelies. These tires fill the gap pretty well, I want the same if not more gap to be filled up.
1999 Solara SE (5S-FE)
Eibach Springs
Bilstein Struts
Whiteline Swaybars (Front and Rear)
TRD Quick Shifter
A'pexi World Sport Cat-back exhaust
Ripp Mods Header
K&N Air Filter
RESISTANCE IS FUTILE
if < 1 ohm
Yanahdi is offline   Reply With Quote
Old 12-17-2003, 11:23 PM   #2 (permalink)
View Tubbyc's Photo Gallery
I think so
Tubbyc is offline   Reply With Quote
Old 12-18-2003, 12:11 AM   #3 (permalink)
my name isn't really Bob
View Fresco Bob's Photo Gallery
k, my rents just got a gen 5, came with trd suspension, rides pretty low, like from the side view you can't see the very top of the tire, and they are brand new snow tires, and on the side it says p215, thats the only number i could find, and the rims are 16'', hope this may help
Fresco Bob is offline   Reply With Quote
Old 12-18-2003, 12:14 AM   #4 (permalink)
camry Wookie
View gaak's Photo Gallery
i have a set of 16's and i'm running 205/55ZR16 tires on them. that was what we calculated would keep the speedometer exactly the same as stock size 14" rims, since my pops is annoying about that stuff.....
gaak is offline   Reply With Quote
Old 12-18-2003, 01:15 AM   #5 (permalink)
actually what I'm looking for is the second series of numbers (the sidewall %)
when you look at the tire you should see three divisions of numbers:
example --> 215/45/17
In your case Fresco I really want to know the second division of numbers if you could find that out it would be a big help.
Eibach Springs
Bilstein Struts
TRD Quick Shifter
Ripp Mods Header
K&N Air Filter
if < 1 ohm
Old 12-18-2003, 01:22 AM   #6 (permalink)
i know how the usual way goes, #/#/#, but all i can see is P215/60R16, so would that just be the same as 215/60/16?
are the gen1 solara and gen5 cam close enough in dimensions that the tires fit the wheel wells the same?
Old 12-18-2003, 03:36 AM   #7 (permalink)
View cdssolara's Photo Gallery
Actually, 225/45/16 will have a noticeably smaller diameter than your current tire. 225/50/16 will be better, but still a little smaller than stock. 225/55/16 will be closer to stock, although just slightly bigger than the stock diameter. I'm using that size on my 01 Solara with Eibachs and Tokico struts. Fills up the wheel wells nicely.
cdssolara is offline   Reply With Quote
Old 12-18-2003, 12:09 PM   #8 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
The higher the first number, the larger the diameter of the wheel. The LOWER the second number is, the WIDER the tire is. The last number is for the size of the Rim it will fit around.
Now, that Letter that you see somewhere around the size is the SPeed rating. The higher the letter rating the better the tire for High speed driving. Anything over R or S is good for driving over 100+.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 12-18-2003, 01:23 PM   #9 (permalink)
That's not quite correct. Using 225/45/17 as an example, the first number, 225, is the width of the treaded part of the tire, expressed in millimeters. The second number, 45, is called the aspect ratio. That is a measure of the sidewall height, expressed as a % of the tread width. Therefore, the sidewall height is 45% of 225 or 101.25 mm. You're right about the last number, which is the rim diameter, expressed in inches.
Old 12-18-2003, 01:48 PM   #10 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
If you're currently using 205/65/15's you can use:
205/60/16
215/55/16 (what I'm using)
225/55/16 (riskier but should work depending on offset of rims)
I know for the 4 cyl Camry, the stock size tire is actually 195/70/14, but your 4 banger is the same as my V6. The sizes above are for my V6, stock size 205/65/15.
Silver Streak is offline   Reply With Quote
Old 12-18-2003, 03:24 PM   #11 (permalink)
205/60/16
ahh yes good info everyone, I highly appreciate it.
My 99 Solara came with 195/65/15 but I upgraded to the 205.
Ok, judging from the input so far I may try and go with 225/50(or 55)/16 if the 225/45/16 doesn't fill it up, either way I gotta wait about 7-10k until my current tires go.
BTW Fresco Bob: P215/60R16 is the same as 215/60/16 as far as sizing goes.
Now since that's solved does anyone have any gripes about Kumho Ecsta Supra 712s? These are the tires I'm planning on getting.
Eibach Springs
Bilstein Struts
TRD Quick Shifter
Ripp Mods Header
K&N Air Filter
if < 1 ohm
Old 12-18-2003, 03:54 PM   #12 (permalink)
well it has supra in the name, so they must be good
Old 12-18-2003, 06:56 PM   #13 (permalink)
Banning is an art.
Actually I may have made a mistake. I dunno if the stock 14" camry tire size is 195/70/14 or 195/65/14...I'm sure someone who has 14"s can confirm that.
Old 12-19-2003, 02:21 AM   #14 (permalink)
If your car came with 195/65/15, then the 225/50/16 size would probably be your best bet. It's almost exactly the same diameter as your stock tires.
Old 12-19-2003, 10:05 AM   #15 (permalink)
MOUTH SLAP!
Thanks for the correction. Thats what I love about TN; when someone committs an error, they get corrected without flaming.
Anyways, when choosing a type of tire remember that some are louder than others. I bought 2 Yokohamas for the rear and they are loud! They make this humming noise that gets annoying after a while. Especially between 20-40mph!
I found that Michelins are the best for me. They are quite and grip pretty good. They are also some of the most expensive
