rear struts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2002, 10:37 PM   #1 (permalink)
View mean_green's Photo Gallery
Everytime I go over a speed bump or hit a bump in the road, the back of my 93 camry sounds like a squeeky bed. Are my struts gone bad, if so how do i tell if i need to get sealed or the servicible kind?
mean_green is offline   Reply With Quote
Old 03-04-2002, 10:41 PM   #2 (permalink)
View rObsolete93LE's Photo Gallery
I JUST noticed the same problem with my Cam... hope to hear something good, Im replacing my sh** too.
rObsolete
rObsolete93LE is offline   Reply With Quote
Old 03-04-2002, 10:45 PM   #3 (permalink)
View 93camryv6's Photo Gallery
I have the same problem. I hope someone knows the answer.
93camryv6 is offline   Reply With Quote
Old 03-04-2002, 10:49 PM   #4 (permalink)
Toyota Nation Wanderer
View Camry726's Photo Gallery
It's not so much the struts that are squeaking it's the bushings in the back. I told my mechanic about the noise before and he told me it was probably just the bushings that need to lubricated.
Camry726 is offline   Reply With Quote
Old 03-04-2002, 10:52 PM   #5 (permalink)
View soundlzrd's Photo Gallery
i think it must be the age, i had the same thing. speaking of which, anyone make urithan bussings?
soundlzrd is offline   Reply With Quote
Old 03-04-2002, 11:02 PM   #6 (permalink)
View speedemn's Photo Gallery
If it is a squeak then it could just mean that your struts or swaybar bushings just need lubrication. When you take it in for tune-up at Toyota they will lubricate everything that needs to be lubricated. Drive it in and let them look at it the next time you take your car for an oil change even.
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
Old 03-04-2002, 11:04 PM   #7 (permalink)
RUN WHAT YOU BRUNG
View 92CAMRYGTS's Photo Gallery
my 92 des the same thing. if i remember correctly my toyota mechanic told me it was the bushings for the sway bar orsomething back there but it was definatey the bushings. when i get the whiteline sway bar and out it in the urethane bushings i'll le you know if the sound goes away.
92CAMRYGTS is offline   Reply With Quote
Old 03-04-2002, 11:16 PM   #8 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
I have the same noise too...from talking to everyone, it's most likely your rear sway bar bushings.... It's gets really annoying when going over little tiny bumps and ridges in the road. If you want, you could try lubricating the bushings with marine lithium white grease. This may take away the noise for a few months...but you'll probably have to regrease it later on. It's a common problem for Camrys.
Anish: the check's in the mail for the swaybar....
Silver Streak is offline   Reply With Quote
Old 03-04-2002, 11:19 PM   #9 (permalink)
Bare backs like Tarzan
View DaksGT's Photo Gallery
Just a though might wanna check energy suspensions poly urethane bushings and see if they make em for your application
DaksGT is offline   Reply With Quote
Old 03-04-2002, 11:22 PM   #10 (permalink)
Thanks Henry. So far I have only received payment from 2 guys. A whole bunch is probably in the mail for me this week.
2003 BMW 540i 6-spd
