quick general question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2003, 11:12 PM   #1 (permalink)
View luisitol's Photo Gallery
for headlight 9006 blubs are 100W too much, will they have a negative effect on the wiriing/harness? If so is 65W the max then? Thanx guys
Luis
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
luisitol is offline   Reply With Quote
Old 12-19-2003, 11:18 PM   #2 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
Re: quick general question
Luis
The amperage draw of the 100W is going to be what determines if the wires will handle the current without frying. However, I do not know what the amperage rating of the wires to the bulbs is or what the 100W bulbs will draw.
Higher voltage-> Lower amperage
Lower voltage-> Higher amperage
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 12-19-2003, 11:52 PM   #3 (permalink)
so which is better?
Old 12-20-2003, 12:07 AM   #4 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
some people have melted their wiring harnesses with 100W bulbs
-Nick
Nick is offline   Reply With Quote
Old 12-20-2003, 12:11 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
If your gunna use 100W bulbs I suggest that you upgrade the harness. Otherwise you might end up frying the stock harness.
"Skoolin' the unlearned!"
Old 12-20-2003, 12:28 AM   #6 (permalink)
65W bulbs it is then, thanx guys
