2000 camry thermostat - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2008, 11:03 AM   #1 (permalink)
View drevil2000's Photo Gallery
Good Morning:
I own a 2000 camry and it only has 61,000 miles. I am going to change the coolant and want to know
is it necessary to also change the thermostat at this point? The parts rep at the dealership said it is a
good idea to replace it but I have never replaced one after changing the coolant. Is he just trying to sell me a thermostat? Thank you for your input on this>
drevil2000 is offline   Reply With Quote
Old 11-01-2008, 11:32 AM   #2 (permalink)
just a nobody
Usually not necessary unless you are experiencing some sort of cooling system related problem.
N.E.O.
Old 11-01-2008, 12:15 PM   #3 (permalink)
Tom 2000's Avatar
Gameroom cash: $201800
View Tom 2000's Photo Gallery
I second that.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 11-01-2008, 12:23 PM   #4 (permalink)
changing coolant
Good Morning:
I forgot to mention one thing from my last posting. I am changing the coolant on my 2000 camry
after 61,000 miles (I have never changed it previously). Should I remove the lower radiator hose
that goes into the radiator or just drain the coolant from the white stop **** valve at the bottom of
the radiator. In other words, what is the best way to drain all of the coolant out?
Thank you
Old 11-01-2008, 12:39 PM   #5 (permalink)
View toyomoho's Photo Gallery
What engine?
To get the most coolant out also remove the engine drain plug.
After draining the system, remove the T-stat and flush the engine with clean water. Do the same for the radiator.
If you want to go a step further, remove a hose going to the heater core and flush it with water.
Old 11-01-2008, 05:22 PM   #6 (permalink)
just a nobody
If you really want to drain more coolant out there are drains for the block, one on each side of the V6 and one at back side of the 4.
N.E.O.
