Leak under oil filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2002, 04:50 PM   #1 (permalink)
View merchjo's Photo Gallery
Hey guys, I noticed the oil filter adapter is leaking oil from underneith. Is this a common problem? Is it easily fixed?
merchjo is offline   Reply With Quote
Old 03-05-2002, 05:33 PM   #2 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
What's an oil filter adapter?
Anyway, if you mean where you screw in the oil filter, check to see that the old rubber gasket from the old filter isn't on there. One time I left the old seal on, drove off and pulled an Exxon Valdez on my street...the stain is still there after 4 years....
Silver Streak is offline   Reply With Quote
Old 03-05-2002, 05:37 PM   #3 (permalink)
I have a adapter that is between the block and the filter. It has 2 3/4 heater hoses running from it. Under that adpter the oil is leaking when the engine is cold.
Old 03-05-2002, 08:42 PM   #4 (permalink)
Gort1's Avatar
View Gort1's Photo Gallery
If I remember correctly there is a o-ring under the adapter. Also if you remove the oil filter you should see a large nut recessed below the base in the center, you could try gently tigten it. If not you will have to go to your dealer for the new ring and repl it. The cold contacts the rubber and it weeps, probaly doesn't leak once it is warmed up. Hope this helps
Gort1 is offline   Reply With Quote
Old 03-05-2002, 08:44 PM   #5 (permalink)
budking686's Avatar
View budking686's Photo Gallery
This probably isn't the case but you could have a bad seal on the oil filter because it was over-tightened or it is not tightened enough...if you can twist with your hand still then that could be the problem
you can reach me on AIM @ budking52r
1996 Camry 2.2L
Waiting until I graduate to buy a 2005 Toyota Tundra V8!
budking686 is offline   Reply With Quote
Old 03-09-2002, 07:10 AM   #6 (permalink)
It was the o-ring under the filer housing. A $3.00 part. Thanks for your help.
Old 03-09-2002, 10:39 PM   #7 (permalink)
View Meisner's Photo Gallery
Just an FYI: That device is the oil cooler. It uses coolant to cool off the oil by circulating it around the oil.
Steve
1996 Turbocharged Camry 5S-FE (4 cyl)
http://www.meisners.net/camry
Meisner is offline   Reply With Quote
Old 03-10-2002, 12:46 PM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Did you replace both o-rings?
Theres one underneath the stud that the filter screws onto and another one underneath the adapter (in between the adapter and the block).
"Skoolin' the unlearned!"
Old 03-03-2011, 11:11 AM   #9 (permalink)
View vx21's Photo Gallery
oil fiter bracket o-ring
Hey guys im having the same problem with my camry it slightly leaks under the oilfilter adapter. does any one know where i can order the oil filter bracket oring for my 96 camry 4cylinder? I cant find one any where. thanks in advance
vx21 is offline   Reply With Quote
Old 03-03-2011, 12:00 PM   #10 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
LOCAL OR ONLINE DEALER
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
