No reverse Lights? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2008, 09:45 AM   #1 (permalink)
View Herrmann61789's Photo Gallery
No reverse Lights?
My vermont ispection is coming up and i have no reverse lights ive put new bulbs in it and they still wont work what could the problem be its not a fuse all the fuses are good its a 93 camry
Herrmann61789 is offline   Reply With Quote
Old 11-03-2008, 09:54 AM   #2 (permalink)
View PDX_1ton's Photo Gallery
There is a switch located on the pumkin (rear dif) you probably need to replace. I had a '87 4speed that went out. I suggest getting a tech manual to find it.
PDX_1ton is offline   Reply With Quote
Old 11-03-2008, 10:00 AM   #3 (permalink)
View toyomoho's Photo Gallery
Determine if power is actually getting to the sockets.
Check the wiring harness where it jumps from the chassis to the trunk lid. Often in this area the wires start to chafe or can break due to trunk usage.
