Originally Posted by silvervette96
Hello everyone. I just registered and have a power window question
I have a 2000 Camry XLE. the right rear window will not go up or down. I removed the door panel and did the following:
1. Removed the wire leading to the motor and checked the voltage going to motor. with the switch in the "up" position i get 12.1 volts. with the switch in the "down" position i get 0.5 volts. I removed the window switch from the opposite door to check the switch and got the same voltage readings with a different switch.
2. Then i checked the voltage using the driver's door main control switch. i get "zero" voltage either way on the right rear door. i removed the entire left rear panel and checked the voltage from the main door switch. i get 12v up and 12v down.
3. why is the right rear door window not getting the correct voltage?
Thanks.
mel
Hi Mel.
My advice is based on the wiring diagram of the 97 LE( I don't think toyota changed it much since)
1. How are you measuring those voltages?
Your meter should be *across* the up/dn terminals(not to gnd) in which case your meter should read +12v or -12v depending on the switch up/dn direction.
2. With all switches at rest, you should be reading close to 0 ohm across the RR door terminals that feed the motor(motor disconnected) and 0 ohms from both terminal to ground, if you don't, you have either a problem in the driver door master switch (Bad wiring or a bad switch) or broken/bad (oxidised)connections between the driver door and the RR door.
Is it possible to move the wiring harness from the LR driver door switch to the RR driver door switch, or swap those 2 switches? If you can do that it will point to either a bad switch or bad interconnect harness.
HTH
JerryR
