2000 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2008, 08:12 AM   #1 (permalink)
View sprinkle59's Photo Gallery
2000 Camry
Hello, my camry headlights will only work on bright.any suggestions?
sprinkle59 is offline   Reply With Quote
Old 11-07-2008, 11:39 PM   #2 (permalink)
View toyomoho's Photo Gallery
Car with or without daytime running lights.
Old 11-08-2008, 10:06 AM   #3 (permalink)
without, the lights come on automatically when it gets dark. thanks for the reply !!!!
Old 11-08-2008, 10:44 AM   #4 (permalink)
just a nobody
Burnt out bulbs or wiring problem, can cause what you have decribed.
N.E.O.
Old 11-08-2008, 11:28 AM   #5 (permalink)
Are the high beams also controlled by this system. Meaning if the auto ON system is OFF you have no lights. When the system is ON you should have both high and low beams but only have high.
Do the low beams work in none auto ON mode?
The combination switch on the steering column should have a manual on selection.
