injectors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2003, 12:38 PM   #1 (permalink)
View high c's Photo Gallery
injectors
the 90 camry came with 200cc injectors right? will injectors from about the same year celica (give or take a cuple of years) fit with out mod? what do the green head injectors flow?
Thanks
"I live my life a 1/4 mile at a time" or "burn rubber not your soul" eather way you sound like a retard
high c is offline   Reply With Quote
Old 12-22-2003, 07:52 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: injectors
Yes if its a 3S-FE.
Should fit.
Celica's were available with a 3S-FE.
Which green ones? You need to be more specific (engine code would help).
"Skoolin' the unlearned!"
Old 12-23-2003, 09:02 AM   #3 (permalink)
the celica hade a 3sge in it, will the injectors from the celica still fit in my stock camry fuel rail and in the head?
Old 12-23-2003, 08:45 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
3S-FE injectors come in low and high impedence.
3S-GE injectors are high impedence.
If your 3S-FE injectors are low impedence you need a resistor pack to use the 3S-GE injectors.
As for fitting or not you'll have to find out for yourself.
http://www.geocities.com/MotorCity/P...Injectors.html
Old 12-25-2003, 02:06 PM   #5 (permalink)
i cant tell if i have high impedence or low impedence, i have a 1990 3sfe can you tell me what i have?
Old 12-26-2003, 02:59 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
Check the link I posted above and match the connector and color of the injectors.
Old 12-26-2003, 12:23 PM   #7 (permalink)
some times my own stupiddy makes me wounder
Old 12-26-2003, 06:16 PM   #8 (permalink)
YES 300cc INJECTORS FOR ME
