generation 2 clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2003, 09:04 PM   #1 (permalink)
View TubRog5's Photo Gallery
generation 2 clutch
Quick question..
Does the generation 2 have a hydraulic clutch or a cable clutch?
Thanks for you time..
TubRog5 is offline   Reply With Quote
Old 12-22-2003, 10:28 PM   #2 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Its a hydraulic clutch. There is an easy way to check to tell what you have. Just look to see if you have another resevior that takes brake fluid. If you do have to resevoirs one bigger and one little then you have a hydraulic clutch. If you don't then you have a line clutch.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 12-23-2003, 06:13 PM   #3 (permalink)
Thanks, I appreciate your help. It does feel like a hydraulic clutch, but considering its an old car. I thought theres a chance it might be cable.
Old 12-24-2003, 08:40 AM   #4 (permalink)
SCCA Tech Services
They have had hydraulic clutches for a long time. My 81 celica is a hydraulic clutch and I beleive all celicas ever have been hydraulic even the 1970's celicas.
Brian Harmer
