Brake Hissing in the Cabin - 2007 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2008, 08:41 AM   #1 (permalink)
View Tadclan's Photo Gallery
USA Brake Hissing in the Cabin - 2007 Camry
Has anyone else had there Brake Power Assist Unit fail in less than two years?
Is anyone else experiencing a hissing noise in side the cabin when applying pressure to the brake pedal?
I have just taken mine into the dealer after hearing the noise and then feeling very soft braking. The diagnosis was that the hissing is from the a leak in the power assist unit which essentially renders the ABS brakes useless in an emergency situation.
Curious if anyone else has run into this - seems like a serious part defect - possible recall issue!
Tadclan is offline   Reply With Quote
Old 03-07-2013, 11:23 AM   #2 (permalink)
View acedude450's Photo Gallery
Anyone have any info on this?? I recently did a motor swap and the hissing noise come only when braking and it was not there prior to motor swap, I already changed the vacuum switching valve on the back of the air box any other ideas guys??
Sent from AutoGuide.com Free App
acedude450 is offline   Reply With Quote
