Hi All,
It's time for me to change the timing belt on this '98 camry (4cyl).
Has 77,000 miles on it.
Questions If you have changed it in this car or similar one:
(1) how long did it take you?
(2) should I use dealer belt or aftermarket HNBR type (that's Hydrogenated Nitrile rubber for those who want to know) info on technology here:
http://www.azom.com/details.asp?ArticleID=537
Also, the nitrile type belts have a lifetime warranty and can handle higher heat and resist oil damage. Aftermarket cost is $33.
Dealer belt costs the same but they couldnt tell me at dealer whether it was Nitrile type or not so I doubt it is.
(3) Recommendations for other things I should do while in there - like is it necessary to change ALL of the following or just some of the following: Idler, Tensioner, cam seal, crank seal, waterpump.
Note - my waterpump was changed by the Dealer back when it had 26,000 miles since it was leaking and under warranty (there was a known problem with the orig. pumps in the '98 camry's).
(4) ANY other parts or things people suggest doing while changing camry Timing belt?
Cheers,
Kim
