Installing new rotors, need help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2003, 03:41 PM   #1 (permalink)
Killa Clean Gen 3
View Gen3cruiser's Photo Gallery
I'm getting new front rotors, mine are worn out.
First off, whats the best rotors I can get without new calipers?
Second, anyone know of brake kits for the car?
And most importantly, if I just get stock rotors how do I install them? What do I need, and is it hard to do? Is there anything to adjust, or is it a direct swap and no fuss?
Thanks
222,000 miles, dead, car wreck. RIP
Gen3cruiser is offline   Reply With Quote
Old 12-23-2003, 04:15 PM   #2 (permalink)
TN Ass Man
DrtySthV6SE's Avatar
View DrtySthV6SE's Photo Gallery
should be the same as getting your rotors turned and putting them back on no big fuss. Take wheel off, unbolt the caliper from the back of the rotor, take caliper off, take rotor off, put new one on, slide caliper back over rotor (sometimes hard to do because the pistons in the brakes begin to close, you have to pry them back open (does anyone know an easier way to do this)), bolt caliper back on and put wheel on.
Pioneer Premier, Elemental Designs, SoundSplinter, Resonant Engineering Audio, Stinger, Optima, Rockford Fosgate
DrtySthV6SE is offline   Reply With Quote
Old 12-23-2003, 04:52 PM   #3 (permalink)
Killa Clean Gen 3
Nice, guess I'll put them on my self. Just ordered Brembo rotors, so that should give some extra stopping power. So theres nothing I need to do right? No machining, no adjusting, just take the olds ones off and put the new ones on?
I know I'm sounding like a dork on here asking all of these simple questions. I'm into cars, just don't have any experiance hooking them up. Thanks for being patient with me.
TOYOTA GEN 3's RULE!!! HAHAHAHA
Old 12-23-2003, 05:40 PM   #4 (permalink)
TN Ass Man
well it is best to get new pads with new rotors but no turning of the rotors should be needed
Old 12-23-2003, 07:06 PM   #5 (permalink)
Killa Clean Gen 3
Well, the pads have only 15K on them, so are they still alright to use? Or should I get the pads to?
If I do get the pads is it something I can do, or should I leave that to a mechanic?
Old 12-23-2003, 08:42 PM   #6 (permalink)
Killa Clean Gen 3
Anyone? Trying to order them before Christmass if I do need them. Thoughts?
Old 12-23-2003, 11:23 PM   #7 (permalink)
View phatboy555's Photo Gallery
if you're gonna do the calipers on your own, you can do the pads on your own
don't know the answer to whether or not you can still use your pads though sorry
phatboy555 is offline   Reply With Quote
Old 12-23-2003, 11:41 PM   #8 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700765
iTrader Score: 6 reviews
View EKam's Photo Gallery
Rule of thumb is you shouldn't install fresh rotors and pads at the same time.
One is suppose to break-in before the other.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 12-23-2003, 11:47 PM   #9 (permalink)
Killa Clean Gen 3
Perfect! Thats what I needed to know. Thanks, that really helps. How long should I break the rotors in before I get new pads then, or should I? they have 15K on them, how long pads typically last?
Old 12-24-2003, 02:44 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You forgot about the caliper bracket.
"Skoolin' the unlearned!"
Old 12-24-2003, 04:39 PM   #11 (permalink)
Killa Clean Gen 3
When I do get new pads what are some good ones with good modulation, stopping power and decent life?
Old 12-30-2003, 11:00 PM   #12 (permalink)
Killa Clean Gen 3
Well my new rotors came in, Brembo disc. anyone know how much getting them machined would cost? If it's up there I'm gonna let the dealer do it all.
Anyone recomend a good pad for them?
Old 12-30-2003, 11:17 PM   #13 (permalink)
View OEMonkey's Photo Gallery
hmm. all new cars come with fresh rotors and pads at the same time.
you coulda saved some money and stayed with OEM rotors. and how did you know they were worn out? did you measure for minimum thickness to see if they can be turned? or did they just have hot spots.
OEMonkey is offline   Reply With Quote
Old 12-30-2003, 11:19 PM   #14 (permalink)
Killa Clean Gen 3
They can't be turned, too thin. The Brembo rotors cost me the same as OEM from the dealer, $105 for the front set.
Anyone know of good pads for them, and cost to get my new rotors machined?
Old 12-30-2003, 11:24 PM   #15 (permalink)
N/A bites
Tercel GTS's Avatar
Why would you get new rotors machined?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
