I kinda do, but not for a 97 Camry, sorry. Info provided below was done on a 2nd gen Camry.
1) Raise the front of the car and support with side/chassis stands.
2) Get most of the power steering fluid out by diconnecting the return line to the reservoir and then turning from full lock to full lock. Do this with car raised, makes turning easier, do it with engine off.
3) Remove crossmember, any covers in the way and disconnect exhaust. Depends where and how it's routed for your v6, but after the exhuast manifold(the pipes, not where it bolts into the engine block), so that you have more working room. You can work it out yourself, i don't know as i did it on my i4.
5) If possible, remove pump from engine block or member ( i think that US had the pump mounted on the cross or centremember, but mine was on the block via mount). If you can't just move onto next step.
4)Disconnect the power steering hoses, making note of which hose is which (one is high pressure and one is low pressure). High pressure is between pump and rack, low is between reservoir and pump.
5) Then if you haven't already, take the pump off.
Yay! half way done.
Get the new/re-conditioned pump and high pressure hose gaket.
5) Connect the hoses back onto the pump and re-mount pump or vice versa. Make sure you get a new high pressure hose gasket and fit it.
7) Re-attach everything you disconnected (exhuast, crossmember and covers)
8) Bleed system. Fill with watever the manual says, should be ATF Dex 3/III
In a nutshell, really. You should get the general idea, but if you can't do any of the above yourself or wokr out how to, i'd suggest you to back away from your tools and take it to a mechanic. Similarly, if you don't have the tools to do certain things, either buy them or take it to a mechanic. You NEED a good breaker bar and torque wrench to get the crossmember back on properly. Mine needed to be torqued to 207Nm. Don't know what yours needs to be.
