Theres something wrong with my car..I have to always jumpstart it. The car runs fine tho'. I dont know if its the alternator or the starter? but If I turn off the car and I wait 5 minutes...i could start it again. But if it has been sitting for a while it wont start. the alternator seems to be charging fine...the battery is being drained while its off. Any ideas? Thanks for your help
I have the same problem, but then again my car has over 330k Km on it, but from a troubleshooting point of view, you may not have the same problem.
Get a Digital Volt meter if you don't already have one. Get something cheap not a $400 flukes. You can get one for around $20+
Check the charge of the battery it must have 12.6V = 100% state of charge with Specific gravity of 1.270
12.4V = 75%
12.2V = 50%
12.0V = 25%
11.8V = 0%
Does your startor make a sound when you try to crank the engine over? (clicking)
You also said that it turned over after you jump start it, does it start everytime you jump start it? If yes, there's nothing wrong with your stator at all. It takes alot of power to crank the engine...ALOT. So much that sometimes old batteries can't supply or cheap batteries - get batteries have the right CA (cranking amps) or CCA (Cold cranking amps) for your car. If you are jump starting a car, you are basically connecting 2 batteries in a series - you still have 12V, but 2X the cranking power.
You can bring a dead battery to life again with a charger, if you can find a shop or NAPA or anywhere that can charge your battery for you, then you save lots of money. Make sure you see him charging it and not replacing your battery with another old one... How cold is it where you live? Temp. makes a great difference.
A battery has plates and liquid inside and the acid is what makes electicity when a demand is there. Over time the plates will begin to sulfate or sometimes the fillings from the battery collects on the bottom and it shorts out the battery... now you see how it is really hard to visually look at the battery and say what is wrong. Again, I am only assuming that your battery is the problem and nothing else.
I have this problem because I did ran stereo equip. and it does drain battery big time. If you bought your car used, make sure that there are no other wires connected to the positive terminal (cathode) other than the OEM wires that are going to the fuses.
So check your CA or CCA, it must meet Toyota's Specs for that car.... Tell us more after you ran the test...
Me, Mine, mods...
1988 Camry
No mods
way to check in the alternator is charging... test the battery with a multimeter. before turning the car on, the battery should be between 11.8 and 12.8 about. when the car is runnig and the alternator is working properly, the voltage should vary between 13.8 and maybe 15 depending on RPMs.
I was told an alternator shouldn't put out more than 14.2 volts... Hmmm... strange.
First Gen 2 with a Flowmaster
Shot transmission, but it's all good.
yup, 14.4V it is...I just checked mine...read 12.45V before starting and 14.37V on idle and remained within 0.02V of that no matter how high I revved it.
With everything electrical on (high beams, rear defogger, blower, dome light/trunk light, stereo, wipers, hazzard lights, engine cooling fan) it dropped to back to 12.45V.
Does that seem healthy enough or should I have mine checked out too?
Originally posted by 'rollaholic With everything electrical on (high beams, rear defogger, blower, dome light/trunk light, stereo, wipers, hazzard lights, engine cooling fan) it dropped to back to 12.45V.
After turning on all these accesories, did you measure voltage at idle and while revving it?
