Compression Test Results - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2003, 09:23 AM   #1 (permalink)
View GEN3CAM's Photo Gallery
I did a compression test this weekend since I changed out the plugs that came in the car. I put in a set of NGK V-Powers. I have always had good results with NGK's in my DSM's so I used them in the Camry as well. Anyway here were my results..
190-190-190-192
I don't know what the tolerance is on the 5S-FE but I would assume these are good numbers. I don't have a factory service manual yet so can someone tell me what is says about where it should be at? Thanks,
Chris Williams
GEN3CAM is offline   Reply With Quote
Old 12-29-2003, 02:59 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
i'd say those are some pretty strong numbers
-Nick
Nick is offline   Reply With Quote
Old 12-29-2003, 03:10 PM   #3 (permalink)
View luisitol's Photo Gallery
wht items did you need to run the compression test? I'm gonna have to do it in the next week or two.
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
luisitol is offline   Reply With Quote
Old 12-29-2003, 03:11 PM   #4 (permalink)
Nick's Avatar
a compression gauge... pull the wires off the rest of the spark plugs so the car won't start and crank for a couple of seconds
-Nick
Old 12-29-2003, 03:23 PM   #5 (permalink)
What you want to do is remove all the spark plug wires from the plugs. Then remove ALL 4 plugs. In the fuse box under the hood remove the EFI FUSE. Use a good quality compression tester that holds the max pressure. Screw the compression tester into the plug hole and make sure it is sealed well. Crank the engine over 6 times while pressing the accelerator to the floor. Check the psi reading. Check each cylinder.
Chris Williams
Old 12-29-2003, 03:49 PM   #6 (permalink)
cool, thanx for the confirmation on the process thats what i thought it was. Where did you get you rcompresion tester? I might have to borrow one from Autozone for the day
Old 12-29-2003, 03:50 PM   #7 (permalink)
I borrowed it from a friend a long time ago. He ended up giving it to me.
Chris Williams
