The tire will need to clear your struts. That's the only physical fitment issue you may run into.
However, it's not something I would recommend.
- The taller sidewalls will make your handling suffer
- Your speedometer will read slower.
- Your net gain in ride height is only 1/2 of the 1.6". The only increase in ride height is from the centerline of your axle to the contact patch on the road (bottom), the other half is just filling empty space in your wheelwell.
- Try finding a 195/80R14 size at a tire store, you'll be lucky to find even trailer tires in that size...
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
