running rich! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2004, 04:56 PM   #1 (permalink)
View high c's Photo Gallery
running rich!
i just put 300cc injectors into my 90 camry with a 3sfe. every thing working roght no fuel leaks and all the wiring is the same but my car is running so rich, rich enough to stall it when i give it some gas to try to speed up. is there anything i can do to lean it out? i put the 300cc injectors in because i am puting a turbo on soon so i will need more gas. anything ideas you can give me will help alot thanks
"I live my life a 1/4 mile at a time" or "burn rubber not your soul" eather way you sound like a retard
high c is offline   Reply With Quote
Old 01-01-2004, 05:14 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
put your stock injectors back in till you put the turbo in
in theory they should still work fine, maybe they`re just hooked up wrong
-Nick
Nick is offline   Reply With Quote
Old 01-01-2004, 06:09 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $462410
iTrader Score: 13 reviews
get an safc or something- you'll need it later on anyway
HaHa
Old 01-01-2004, 08:23 PM   #4 (permalink)
is there a way to re-set the ecu, could be the problom? i really dont want to take the 300cc out because to do that (easy) you need to remove the intake manafold and that sucks
Old 01-02-2004, 03:05 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The problem is the injectors.
You have no need for 300cc injectors on a n/a 3S-FE.
You don't need to unbolt the intake manifold. Just unbolt the fuel rail and move it out of the way.
"Skoolin' the unlearned!"
Old 01-02-2004, 07:01 AM   #6 (permalink)
View phatboy555's Photo Gallery
i thought that running bigger injectors even when it's not necessary was still ok...it just meant that they'd run at a lower duty cycle
phatboy555 is offline   Reply With Quote
Old 01-02-2004, 11:42 AM   #7 (permalink)
My car looks good wet
View 90CamryDx3SFE's Photo Gallery
Bigger fuel injectors are for allowing more fuel in... The only time you allow more fuel in is when there's more air flowing into the system... thus enters the Forced Induction issue. Stock injectors are fine till you put the turbo in as others have said. There's no reason to be running 300cc without added air.
First Gen 2 with a Flowmaster
Shot transmission, but it's all good.
90CamryDx3SFE is offline   Reply With Quote
Old 01-02-2004, 08:03 PM   #8 (permalink)
ok, i put the old (200cc) injectors back in and now the car wount start, it cranks fine and theres fuel in the fuel rail but it dosent start no matter how much i crank, any ideas?
Old 01-03-2004, 02:24 AM   #9 (permalink)
Nick's Avatar
did you fuck with anythign else?
if not, then bring it to a garage and pay a stupid amount for a diagnostic since you did stupid shit
-Nick
Old 01-03-2004, 03:14 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
^^ What he said.
Did you hook everything backup properly?
Old 01-03-2004, 03:38 AM   #11 (permalink)
Certified Yo'Mama-ologist
Hook's Avatar
View Hook's Photo Gallery
ummm...what sense is there in adding so much extra fuel to ur mixture if there's no extra air added to burn with it? *sigh*
reset ECU...try again...THEN bring it to a garage and pay a stupid amount for a diagnostic since you did stupid shit
Hook is offline   Reply With Quote
Old 01-03-2004, 04:35 AM   #12 (permalink)
i still don't get it...some of you guys are making it seem as if just because he has bigger injectors that he is automatically receiving more fuel...i don't see why the motor wouldn't put in the same amount of fuel as before since the amount of air coming in hasn't changed...
i think the injectors would run at a lower duty cycle, which is a little better but it's not absolultely necessary...
i think he just installed them wrong or maybe some sensor is screwed...i don't think it is the 300cc injectors alone that is making him run rich
Old 01-03-2004, 10:26 AM   #13 (permalink)
how do you reset the ecu?
Old 01-03-2004, 11:24 AM   #14 (permalink)
Hook's Avatar
disconnect battery...chill a bit...reconnect it...drive around a bit to re-program it to ur driving habits
Old 01-03-2004, 11:44 AM   #15 (permalink)
TN Ass Man
DrtySthV6SE's Avatar
View DrtySthV6SE's Photo Gallery
this makes more sence to me, shouldnt the computer select how much fuel sprays according to the amount of air coming in???
Pioneer Premier, Elemental Designs, SoundSplinter, Resonant Engineering Audio, Stinger, Optima, Rockford Fosgate
DrtySthV6SE is offline   Reply With Quote
