Your problem may be that you are overfilling it....you say it was low...so you put 4 quarts in it. Most dipsticks only display the top quart of oil in the oil pan. You need to add at very most a quart at a time and check the dipstick to see where it is. When a car is overfilled the most common thing to happen is for one or both main seals to leak.
-Black 88 Celica GT, Fully rebuild 3sfe with Custom turbo manifold, Garrett T-25 Turbo, Custom Water/Air Intercooler and piping. (Will be swapping to 3sge head soon)
