Camry Race Car Specs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2004, 01:17 AM   #1 (permalink)
View smt_007's Photo Gallery
Talking Camry Race Car Info???
For those who havnt seen this car its a Camry Race Car beleive it or not, and i just found more info on it enjoy.
Toyota Camry Gen3 3sge Motor
Engine: Transverse 4 cyinder in-line, DOHC, 16-valves, iron block, alloy head, capacity 1998cc
Transmission: Front wheel drive, transverse sequential-shift gearbox, 6-speed plus reverse
Suspension: Front: Toyota Super-strut, coilsprings, gas-filled dampers, anti-roll bar.
Rear: MacPherson struts, coilsprings, gas-filled dampers, anti-roll bar
Brakes: Front: Ventilated discs, 8-piston calipers
Rear: single-piston calipers
Wheels: 8 x 19 inches
Body: Toyota Camry 4-door.
Length: 4530mm.
Width: 1695mm.
Height: 1410mm.
Wheelbase 2580mm.
Weight: 975kg
http://www.ozspeed.net/2002/cars/toyota_camry.htm
Heres my TOY....http://www.cardomain.com/ride/290592
smt_007 is offline   Reply With Quote
Old 01-04-2004, 02:05 AM   #2 (permalink)
View I4 to V6 Swap's Photo Gallery
Thats sweet.
I4 to V6 Swap is offline   Reply With Quote
Old 01-04-2004, 02:20 AM   #3 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
Thats beautiful. I dont dink the random colors on it though.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 01-04-2004, 02:31 AM   #4 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
that has to be a 3sgTe... no way itd be winning races if its not turbo and only 2 liters...
where can I get a transverse sequential-shift gearbox? those gotta be fun
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 01-04-2004, 02:34 AM   #5 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
how about in a small engine n/a class.... there's all kinds of classes out there
oh and smt_007, sure it might have started as a 3sge, but its a race engine, its worth more than you, so if you do the swap, you shouldn't expect much more (the engine does breathe better 21 vs 45 degree valve angle)
-Nick
Nick is offline   Reply With Quote
Old 01-04-2004, 02:39 AM   #6 (permalink)
I understand, im not expecting miracles, i just have an oportunity to get a gen3 3sge so il be putting it in the camry, the engine im getting is a gen3 3sge 123kw or 165Hp , ive been talking to a guy that races 3sges and he said it can make 250hp+ in n/a form, it just depends howmuch you want to spend. These are cars it races against:
http://www.ozspeed.net/2002/cars/default.htm
Old 01-04-2004, 02:43 AM   #7 (permalink)
Nick's Avatar
you got it
-Nick
Old 01-04-2004, 04:21 AM   #8 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
yeah 3sge is a great performance NA engine... if you are going for NA, this is the engine to get for a 4cyl toyota.... the ungrades are endless... cams, pulleys, port & polish, bigger race valves, springs, O/S pistons, fuel rail, injectors, metal HG, added oil squirters, bigger radiator, radiator fan, ignition, fuel computers... etc... the list goes on................ i have no doubt the 3sge can produce 350+ HP as an NA engine.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 01-04-2004, 05:05 AM   #9 (permalink)
View phatboy555's Photo Gallery
8 piston calipers, 9inch wide tires, and roughly 2000lbs...yummy
phatboy555 is offline   Reply With Quote
Old 01-04-2004, 05:36 PM   #10 (permalink)
Yeah i know, i want to do an AllMotor project , and i realise the 3sge is the best motor for it.
Old 01-04-2004, 06:13 PM   #11 (permalink)
I'm a Mac
zoni's Avatar
yeah dude, rock the 3sge!
Dave Zoni
Old 01-05-2004, 08:39 PM   #12 (permalink)
I hope the Camry gearbox will holdup with that power, my camry has 360,000 ks or 223,000 miles on the clock, im unsure if the gearbox and drive shafts will holdup.
Old 01-05-2004, 09:42 PM   #13 (permalink)
Crossdrilled and Slotted
View myconid's Photo Gallery
Is there going to be a group buy on this?
myconid is offline   Reply With Quote
Old 01-05-2004, 11:47 PM   #14 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
"transverse sequential-shift gearbox"
that's a group buy item there
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 01-06-2004, 07:27 AM   #15 (permalink)
CTM/ShiftGate CAMRY
racerhex's Avatar
View racerhex's Photo Gallery
Wow.....I like..... cant wait until I start!!!!
3vz-fe w/ all the good stuff
Does My Wiper Offend You? Look Ma no handles!
www.ctmotorsport.com FOR ALL YOUR CAMRY NEEDS
http://members.cardomain.com/racerhex<----CHECK ME OUT...UPDATED!!!!
racerhex is offline   Reply With Quote
