3SFE Compressor Pulley Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2004, 04:07 PM   #1 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
Ok Guys...
Since my compressor went out on my I4 (bad pulley), I decided to remove the pulley from the compressor, giving me enough clearance to run the non-AC drive belt. This way, I can still drive the car until I'm ready to replace the compressor, recharge the system, etc....
Bad part is that the bolt to the pulley is a pain to get to.
I was under the impression that the bolt is a 10mm bolt.
The clutch to the compressor is really messed up. I managed to pry out the plate that's bolted in with the 3 screws. The clutch is loose inside the pulley, but now I'm having a hard time removing the main bolt to the pulley; with hopes of eventually working the pulley off.
The rest of the compressor can sit there for all I care, until later....
Advice anyone?
Thanks!
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
Old 01-04-2004, 04:16 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Start looking for clips
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
Old 01-05-2004, 03:42 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Did you unbolt the compressor from the block?
I took alook at mine and all I see is a bolt in the middle of the pulley.
"Skoolin' the unlearned!"
Old 01-05-2004, 08:27 AM   #4 (permalink)
View Nico's Photo Gallery
I had the same problem when I installed a/c on mine as I didn't get the new belt very quickly and i didn't want to remove the compressor . What I did (I know this is not a "perfect" solution but it did work : I unbolt all compressor bolts half way, so that there was just a very little space between the compressor and the block, inserted a small bolt at both upper compressor bolts (between compressor and engine block) and rebolt the compressor : the space you get is just what you need to get the non a/c belt run properly .
What I would do later (when you have time) is replace your current compressor with a used one.
Nico
Nico is offline   Reply With Quote
Old 01-07-2004, 07:05 PM   #5 (permalink)
toyrolla's Avatar
Hey Nico, that's a good idea. Those bolts have length, so I should be able to take advantage of the length just to give me enough clearance.
Later on, I plan to replace the compressor.
I'll try that and let you know how I make out....
Thanks Guys!
Regards,
Toyrolla
Old 01-08-2004, 08:13 AM   #6 (permalink)
Thanks Guys!
No problem !!! At least this shouldn't cost you anything in the meantime...
Good luck !
Nico
Old 01-29-2004, 11:00 PM   #7 (permalink)
toyrolla's Avatar
Update:
My attempts to move up the compressor worked like a charm.
I have ample clearance for the belt to run, and my daily grinder is running good! Cost me a few frosebit fingers, but HEY, I got it working, so I don't care....
Thanks Nico, 88LE, and Tercel GTS for your insight and assistance.
Regards,
Toyrolla
Old 01-30-2004, 01:29 AM   #8 (permalink)
Nice to hear you got it !
Nico
