cylinders fire only once, but car does not start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2009, 04:15 PM   #1 (permalink)
View patildg's Photo Gallery
About Toyota Camry 1998 4 cyl.
I had to replace no. 1 connecting rod and piston on my Camry.
To do this, I followed instructions from Chilton maual.
From top of engine, I removed the valve covers, intake manifold, exhust manifold, cylinder head, etc, etc. And from bottom, oil pan, balancer, etc. etc. and replaced the conrod and piston.
I did all put it back together as per instructions, lined up the timing belt correctly, but now when I crank the engine, it does not start.
It appears that when I try cranking after a long while (like first attempt on a new day) upon cranking, all 4 cylinders fire once (but only once) but the car does not start.
If I continue cranking, occassionally the cylinders fire, no start.
Has anybody seen anything similar? Any advice and clues will be appreciated.
patildg is offline   Reply With Quote
Old 01-02-2009, 03:25 PM   #2 (permalink)
nooB nooB noo
View Larzzzz's Photo Gallery
I would bet that your 180 degrees out. your timing is set on the exhaust stroke, not the compression stroke...been there, done that
'06 DCLB Indigo,Scangauge II, Redline tuning hood struts, map light mod, trailer plug mod, LED bed lights Thule X-sporter racks. Aux. back up lights.
Larzzzz is offline   Reply With Quote
Old 06-28-2009, 05:00 PM   #3 (permalink)
car makes lot of smoke
I've finally managed to get the car running. (I had to change piston 1) on this camry.
But the car makes lot of smoke - whitish smoke (burning oil).
When I examined the plug on all cylinders, the cylinder 1 plug has oil on it.
The oil seems to be leaking in that cylinder and burning there.
Anybody knows how to fix this?
Old 07-01-2009, 02:33 AM   #4 (permalink)
Gameroom cash: $926800
iTrader Score: 13 reviews
View ASG14's Photo Gallery
White smoke is Coolant, not oil. Is there oil in your coolant or coolant in your oil?
5 Lug Corolla WHAT?
Old 07-01-2009, 06:30 AM   #5 (permalink)
No coolant in oil or oil in coolant, but oil has turned very dark in just about few hours of idling.
The smoke has bluish tint, so I thought it's oil.
I suspect the piston rings are not exact match (I used the original rings, changed only the piston).
Do the original piston's rings work with a Sealed Power piston?
