Check connections!! ie grounding
I noticed the word BLINK and not DIM, so
1. You need Alternator, more than likely your battery is undercharged, because your diodes (rectifier) in the alternator have given up. you have been driving with your battery, to power the electricals, and engine ignition.
quickest fix, buy a rebuilt (new diodes, bearings, etc.) alternator and change it. Then put battery on overnight charger. Drive car back to place where you got rebuilt alternator, and give them the broken one for them to rebuild and sell again. Good like new results and good warranties with this fix.
CHEAPER: rebuild your altenator with kit. The wearing parts have served their useful life.
2. check brake light switch to see if it's wires are loose, or when pedal is moving, rubbing or straining other wires. On my Chevy it did just that and would short out my dash and radio lights every time i braked until the wire broke or burnt through.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
