well in this case man its perfect because when I do searchs it pops with tones of tranny cooler threads!
But to answer your question tons of poeple are or are planning to use tranny coolers. U running a auto or man.? An auto tranny cooler is real easy, to use it on a man. just tap it into the cooler ring that is on your tranny(hard to get off), in most cases you will need a circulation pump but on the never mans. like in my new solara trans that I got has this allready in place.
Make sure you put a T piece in the lines and hook up a pressure sensor so you can make sure the presure is staying the same as stock, to make sure your circulation is proper!
