I noticed that one other guy had this problem on the board--but I was wondering if it is common or if it is actually an evil and expensive problem...brewing...evilly.
I've got a 94 LE with an automatic and when it's insanely cold out and windy (enough so that I could not replace my fuel filter or clean my throttle body--stupid stupid climate) my car won't switch into third gear for a while. Now this same thing happened on my old Montero and I chalked it up to the Montero being awful and the transmission having not been serviced for five years. It works fine after driving for about five-ten minutes. I checked the fluid today and it looks all nice and bright red--so I guess the previous owners took care of that decently.
Anyone else with an automatic have this happen or is my car showing the same worn transmission signs at 77,000 miles that my previous one did at 170,000?
Thanks.
"If you knew all, you would pardon all"
On my Gen 2, I get a real bad *CLUNK* and shudder when it shifts 1st to 2nd if the car is cold. Although it will occasionally do this when the car is warm as well.
*cries*
First Gen 2 with a Flowmaster
Shot transmission, but it's all good.
I keep it on 35mph roads at max when it's being crazy like that--but the Montero did it more often and so sometimes I would just be traveling along at 50mph in 2nd gear. It got me back though when the transmission failed at 2am on the way to a diner on a highway with 3 friends in the car.
i normally don't warm up the car, hop on highway right away and lately it was (is) extremely cold in NorthEast region, i was shifting into 1st gear, 2nd gear, 3rd gear,and while i shift to 4th gear, the indicator is still below C, and i kept my speed around 45 to 60 mph on 4th gear until it warm up, normally in 30 to 60 secs, then shift into 5th gear, i am wondering if there is any harm to engine or transmission by doing that.
I have experienced the same thing. It actually isn't a problem, it's a safety measure that Toyota uses in their automatic trannies so no one can drive past second gear with a cold tranny/engine and kill it. Don't try to force the car into overdrive or anything. Just keep the rpm's at or below 3000 until the car warms up. Eventually it will shift into third on its own, that's when you'll know that it has warmed up to normal operating temps.
TOYOTAS RULE!!!!!!!!!!!
1995 Toyota Camry TRD
http://www.cardomain.com/id/kaystrd
Out of random curiosity, would anyone happen to know how one of those tranny fluid additives that claims to lower the fluid temp would affect all this--is the fluid what the car's computer measures to make sure things are warmed up enough?
