accelerator sticking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2004, 08:16 AM   #1 (permalink)
View wheatsix's Photo Gallery
Question accelerator sticking
I have a 1990 Camry. Here in the last couple of months, the accelerator has begun to stick. It most often occurs when taking off. Sometimes I have to press the accelerator so hard to make it depress that it overrevs the engine. Like I said, it began happening when taking off out of first gear. But, now it has started to stick when changing gears. Also, every once in a while, it will stick while driving (not changing gears) if I take my foot off the accelerator and put it back on. Can anyone tell me some simple things to try before having to take it to a mechanic. I think it's best to try the simplest solutions before trying more complex things or taking it to the shop. Thanks in advance for any help you can give.
wheatsix is offline   Reply With Quote
Old 01-07-2004, 10:14 AM   #2 (permalink)
eecc's Avatar
View eecc's Photo Gallery
clean the throttle body w/ some carb cleaner
eecc is offline   Reply With Quote
Old 01-07-2004, 10:29 AM   #3 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
Check that the throttle cable hasn't bent somehow or isn't too tight, though typically it goes slack rather than tighter.
Or it could be a nest of wolverines in the airbox.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 01-07-2004, 01:17 PM   #4 (permalink)
There's a post button?
View Yanahdi's Photo Gallery
Do what eecc said, clean the throttle body.
1999 Solara SE (5S-FE)
Eibach Springs
Bilstein Struts
Whiteline Swaybars (Front and Rear)
TRD Quick Shifter
A'pexi World Sport Cat-back exhaust
Ripp Mods Header
K&N Air Filter
RESISTANCE IS FUTILE
if < 1 ohm
Yanahdi is offline   Reply With Quote
Old 01-07-2004, 01:20 PM   #5 (permalink)
TN Ass Man
DrtySthV6SE's Avatar
View DrtySthV6SE's Photo Gallery
yeah i cleaned mine the other day and no more sticking
Pioneer Premier, Elemental Designs, SoundSplinter, Resonant Engineering Audio, Stinger, Optima, Rockford Fosgate
DrtySthV6SE is offline   Reply With Quote
Old 01-07-2004, 01:56 PM   #6 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
properly adjust your throttle cable while your at it
Brandon
arcasmachineracing is offline   Reply With Quote
Old 01-07-2004, 04:02 PM   #7 (permalink)
Bring it !
View WickedGen3's Photo Gallery
sarg
how would you adjust it? i'm not sure how to do this.. please explain??
thanks
WickedGen3 is offline   Reply With Quote
