All ATF Fluid Created Equal? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2009, 02:39 PM   #1 (permalink)
View jderrick's Photo Gallery
Hey folks,
Getting ready to add a little ATF fluid (1999 camry 4-cyl automatic -- it was at the low end of okay, but after 150K I don't figure I get to complain much) and I'm lust wondering -- is it all the same and just buy store brand? Is there any issue with mixing new and old?
Thanks,
JD
jderrick is offline   Reply With Quote
Old 01-18-2009, 10:11 PM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
It''s probably best to stick to well known brands and i'd suggest flushing the system if it hasn't been done in a long time. Mixing is okay as long as it's with the same oil. My opinions anyway.....
Jimnist is offline   Reply With Quote
Old 01-19-2009, 01:19 PM   #3 (permalink)
Thanks for the info! I checked my ATF again today on a day that wasn't 20 degrees and the transmission was better warmed up, and it's fine. But I learned a thing or two, so yay!
Old 01-19-2009, 07:22 PM   #4 (permalink)
View toyomoho's Photo Gallery
This trans was designed for Dexrom III which GM has stopped licensing, as such it may be hard to find a bottled labeled as Dexron III or Mercon/Dexron III. The bottle may now be labeled ATF fluid, read the label to make sure it is a replacement for Dexron III.
Ok to mix old and new fluid.
Old 01-19-2009, 08:38 PM   #5 (permalink)
Hey -- I actually looked at a store today, and as you say, they don't sell the exact thing, but they sell ATF fluid that describes itself as a replacement for Dexron III. Thanks!
Old 01-19-2009, 10:31 PM   #6 (permalink)
Tom 2000's Avatar
Gameroom cash: $201300
View Tom 2000's Photo Gallery
This is what I use on my 2000 Camry LE 4-cyl
Shifts are very smooth now and very pleased with the performance.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
