Tire Pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 01-07-2004, 05:46 PM   #1 (permalink)
Corsulian's Avatar
View Corsulian's Photo Gallery
Tire Pressure
This question is annoying--but ten minutes using the search function brought me nothing useful.
My car doesn't have the info plates on the door jambs, no manual, and the Haynes manual doesn't say anything on this: what pressure should I be using on the old girl?
"If you knew all, you would pardon all"
Corsulian is offline
Old 01-07-2004, 05:51 PM   #2 (permalink)
View smt_007's Photo Gallery
do you have 14 or 15 inch tyres?
Heres my TOY....http://www.cardomain.com/ride/290592
smt_007 is offline
Old 01-07-2004, 05:53 PM   #3 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
The tire pressure is located on the sidewall of your tire.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline
Old 01-07-2004, 06:39 PM   #4 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
no.....thats the maximum that the tire can hold without exploading (otherwise known as going "ford")
31-32 should work.....unless you have really low profile tires
but for stock tires 32 should be fine
alex is offline
Old 01-07-2004, 06:53 PM   #5 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
32 front, 31 rear, with passenger, 32 rear. for gen 3 and 3.5 camry....
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline
Old 01-08-2004, 12:25 AM   #6 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
Dont look on the side of the tire. Heres what you do. Open your glove box. There should be a sticker on it with all the info u need on it. THAT is what you should follow.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline
Old 01-08-2004, 07:36 AM   #7 (permalink)
Certified Yo'Mama-ologist
Hook's Avatar
View Hook's Photo Gallery
shit!!! I been inflating mine to what it says on the sidewall all along...like 34psi...stangely enough, both my front tyres are wearing evenly on the ends (rear tyres are great even tho they're only a month younger than the front ones) .... if I'm not mistaken, that's a sure sign of underinflation
now I'm
Hook is offline
Old 01-08-2004, 09:02 AM   #8 (permalink)
View clutterking's Photo Gallery
I have a 94 LE also, check the glovebox there should be a sticker there. If I remember correctly, it says 28psi under normal conditions and 32psi when its loaded, don't quote me on that. I always keep mine at 32psi.
clutterking is offline
Old 01-08-2004, 10:12 AM   #9 (permalink)
eecc's Avatar
View eecc's Photo Gallery
i thought that inflating to what the sidewall of the tire says is okay since thats max cold tire pressure?
eecc is offline
Old 01-08-2004, 10:25 AM   #10 (permalink)
Corsulian's Avatar
Thanks all,
I think I'm also missing that glove compartment sticker. Melanie is one sketchy gal. That's right, I refer to my car by its name.
Old 01-08-2004, 01:21 PM   #11 (permalink)
MOUTH SLAP!
yeah my sticker is messed up also and I have to refer to my manual.
Old 01-09-2004, 12:44 AM   #12 (permalink)
View crazy_camry's Photo Gallery
sorry to hijack thread, but i have some Falken Ziex 205/50/16's and am unsure what these should be inflated to. any ideas?
crazy_camry is offline
Old 01-09-2004, 07:24 AM   #13 (permalink)
View GEN3CAM's Photo Gallery
It would make more sense to go by the recommended pressure that the manufacturer states for their tire. Most likely you don't have the same make and model tire that your car came with new. You can have the same size tires but sometimes the pressure ratings change if you go with a different speed rating and brand. I look on the sidewall of the tire and look what the maximum PSI. Then I subtract 3-4 PSI from that and use that as my setting. I have never had any problems with uneven wear and the closer you are to the max PSI, the lesser the rolling resistance which equals better performance and better gas milage.
Chris Williams
GEN3CAM is offline
Old 01-09-2004, 10:01 AM   #14 (permalink)
View dbruce's Photo Gallery
Another note.
I have a Gen2 with recommendations for 32 front and 28 back. My gas mileage went down the tubes when I started using this with my new tires. I was using the max pressure numbers (way way to high) and got amazing gas mileage but poor handling when the tires wore.
I decided on 35 front and 32 back. The new pressure makes the ride a bit stiffer and the gas mileage much better. As long as you are filling them below max pressure and above the recommended........you can play till you find a pressure that works for you.
dbruce is offline
Old 01-09-2004, 10:34 AM   #15 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Stock for a gen 3 is 32lbs all round. I have 215/50/17, every brand of tire I've had at that size says 42 max I use about 35.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline
Closed Thread
