Need Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2004, 12:28 AM   #1 (permalink)
MIS
View MIS's Photo Gallery
Need Help
I got 1992 V6XLE camry and Please show me how to change over drive light buld. I got it burn last year.
BLINKER & PARKLIGHT FLASHERS
Cut the ground wire for the parking light. Tape off the end that goes to the
car cos you won't be using it anymore.
Splice the ground wire from the parking light (the bulb socket) to the 12V+
wire of the blinker. You'll need a piece of wire and some crimps to do this.
Parking lights off = parking light and blinker both blink at the same time
Parking lights on = parking light and blinker blink alternately.
Remember to cut the ground wire on the parking and only use the end that
goes to the bulb socket of the parking light otherwise you'll end with blown
fuses. Also verify the wires with a DMM before you cut and splice.
Ground wire on corner light = white wire with black stripe.
12V+/signal wire on blinker = green wire with yellow stripe.
Any diagram or pictures that show me how to install Blinker or parking flashers???
Thank
MIS is offline   Reply With Quote
Old 01-09-2004, 09:56 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
...I posted up those instructions along time ago.
I'll see if I can dig up the diagram that I drew.
"Skoolin' the unlearned!"
Old 01-09-2004, 10:37 AM   #3 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
I did that a while ago... I'm not really sure what you're asking but I just used the existing corner marker light.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 01-09-2004, 10:59 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
Heres the diagram:
Ignore the bottom half of the diagram.
Old 01-09-2004, 02:06 PM   #5 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
i think he needs to know how to replace the O/D light in the gauge cluster in the dash...
in that case, take the radio trim off, then the dash trim, 2 screws where radio trim covers, 2 behind steering wheel above the gauge cluster, then maybe another one on the left somewhere... i forget...
then there are 2-4 screws on the top of the gauge cluster holding that in... find the little black or grey piece that holds the light bulb for the O/D indicator, and pull that out by twisting... go to the autoparts store and see what you can find...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 01-09-2004, 11:59 PM   #6 (permalink)
MIS
Thank you guys
I will do that tomorrow
