3sge - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 01-10-2004, 09:20 AM   #1 (permalink)
View high c's Photo Gallery
3sge
would a coil out of a 3sge and dis cap. make any more power out of a 3sfe? because the ge is made to run at higher rpm? so the spark need to have more power?
"I live my life a 1/4 mile at a time" or "burn rubber not your soul" eather way you sound like a retard
high c is offline
Old 01-10-2004, 10:11 AM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
i wouldnt mix it, thats just me...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline
Old 01-10-2004, 12:04 PM   #3 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Ok dude since you keeping asking if different parts on a 3sge will fit on your 3sfe and give you more power let me explain something to you. Just because one engine produces more power and has the same block doesn't mean you can mix match parts that easily. The reason the other engine makes more power is because of the design difference in the head and the different placement of them and some are excatly the same and some are different. If you want power from 3sge parts then get a 3sge beause other then that you aren't going to gain any power from swapping parts unless you get port design like the 3sge.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline
Old 01-10-2004, 12:11 PM   #4 (permalink)
so you are telling me is by puting a TB from a 3sge that is 1/4 inch bigger than a 3sfe's TB and cuting the intake plumn to take the 3sge TB it wount make a diffrince?
high c is offline
Old 01-10-2004, 01:40 PM   #5 (permalink)
SCCA Tech Services
With all that work you will maybe gain 2 hp if that and you wont even feel that. You are better off just getting your throttle body bored and port matching your intake manifold to that because the gains will still be the same which is very minumal and it will be cheaper. Instead of trying to figure out just how to get more power try and figure out how to be more effecient and reliable along with the performance because you can build a motor to have 500 hp but it wont mean anything if there is no reliablity or effciency in it.
Brian Harmer
Old 01-10-2004, 02:46 PM   #6 (permalink)
i just got a TB and MAF from a 3sge the TB is already on and i need a 3 inch ruber 90 for the MAF and we'll see how she gos
high c is offline
Old 01-10-2004, 04:57 PM   #7 (permalink)
SCCA Tech Services
It isn't a MAF it is an AFM trust me there is a difference in the two. And your effeicency is not going to be as good because you still need to at least port match the intake manifold or your air turbulance is just going to get screwed up
Brian Harmer
Old 01-10-2004, 06:40 PM   #8 (permalink)
i did port match the manifold
high c is offline
Old 01-11-2004, 12:56 PM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Bigger is not always better.
I did some calculations on the 3S-FE as far as airflow.
Displacement = 122.391 CuIn
Assuming 80% VE (volumetric efficiency) and max rpm of 6,000 the engine would need 170CFM.
To flow 170CFM you need a certain size throttle body. I don't know what size TB you would need to flow 170CFM, but once I find somemore formulas i'm gunna prove to you that bigger is not always better.
Heres the calculator that I used:
http://home.tampabay.rr.com/1bking/c...calculator.htm
Bore = 3.39"
Stroke = 3.39"
"Skoolin' the unlearned!"
88 LE is offline
Old 01-11-2004, 09:45 PM   #10 (permalink)
bigger is better
high c is offline
Old 01-11-2004, 10:33 PM   #11 (permalink)
I'm a Mac
zoni's Avatar
noob = 87 posts...
88le = not noob = 1705 posts...
listen to him... he's been around, he knows his shit! he has schooled many throughout the TN career... 88le KNOWS HIS SHIT!
Dave Zoni
zoni is offline
Old 01-11-2004, 10:38 PM   #12 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
You may have your heart set on doing this mix and match deal, which I can understand; especially if you've already started purchasing parts. But at least leave yourself open to the input of others. Both 88le and hotwheelharmer know their shit.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline
Old 01-12-2004, 01:29 AM   #13 (permalink)
I'm a Mac
zoni's Avatar
harmer + 88le = your schoolteachers... they will school you if you arent careful... just search for the thread about swapping a JDM 5sfe in place of the gen 4 camry 5sfe... oh lord... thread starter was 97kamuri i think....
EDIT: "Bigger is better" is what your girl said when i was smackin her ass...
Dave Zoni
zoni is offline
Old 01-12-2004, 02:12 AM   #14 (permalink)
getn groceries in style
jwa276's Avatar
View jwa276's Photo Gallery
lol this is getting way out of hand... he might need to figure it out the hard expensive way (as i point to myself )
jon
'92 Camry SE V6 5spd
jwa276 is offline
Old 01-12-2004, 03:46 AM   #15 (permalink)
Grenaded piston
88 LE's Avatar
bigger is better
Just like those 300cc injectors you installed and complained that it runs rich huh?
88 LE is offline
Closed Thread
