Camry died . Suddenly. No problems before. First it was hard to start, I thought it was nothing, but then it started to choke or something, like there was moisture in the dizzy. And just died.
Engine cranks normally, ECU gives no fault codes. And I have no tools. Distributorcap+wires, coil and rotator were changed last summer with cheap parts. Lucas cap and so on
I think there are three choices, 1)rotator or dizzycap are messed up because of cheap quality.
2) Fuelpump died
3) Timingbelt slipped and got fu*ked up.
Because I have no tools yet, I can't check anything, but codes, I can't do anything. If you have any good ideas what to check, please tell me...
I report more later. Car is Camry 2.0i -90 with 300kKm
Whoops my mistake. I was thinking of a different time where it didn't turn over. I DID have this problem before though, but my problem was probably just some moisture in the distributor cap so all I did was keep revving the gas while it was cranking until the engine managed to start up. A couple days later the moisture disappeared and my car went back to normal.
I had a problem where the car just shut off. Nothing wrong, but it would crank over no problem. Turned out to be the EFI fuse. Check the fuse boxes and see if they are broken.
yeah the efi fuse would make the car crank, but not TURN over... thats the trick that my boys were using the other night to test the supra motor before they started it completely...
