Advancing Timing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2004, 11:21 AM   #1 (permalink)
There's a post button?
View Yanahdi's Photo Gallery
Advancing Timing
I'm going to be going to my mechanic in a little while to get my drive belt and a couple seals replaced. I've been thinking about asking him to advance the timing a bit while he's in there but I'm not sure if it is really worth doing.
Can anyone help me out and inform me if advancing the timing is recommended? I'd like to know what risks/benefits are involved.
Thanks in advance for the help.
1999 Solara SE (5S-FE)
Eibach Springs
Bilstein Struts
Whiteline Swaybars (Front and Rear)
TRD Quick Shifter
A'pexi World Sport Cat-back exhaust
Ripp Mods Header
K&N Air Filter
RESISTANCE IS FUTILE
if < 1 ohm
Yanahdi is offline   Reply With Quote
Old 01-11-2004, 11:45 AM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
it dosen't hurt...
you'll get some nice top end power, but it won't idle as good
-Nick
Nick is offline   Reply With Quote
Old 01-11-2004, 01:04 PM   #3 (permalink)
My car looks good wet
View 90CamryDx3SFE's Photo Gallery
depends on how much you want to advance the timing...
one or 2 degrees, or a lot?
First Gen 2 with a Flowmaster
Shot transmission, but it's all good.
90CamryDx3SFE is offline   Reply With Quote
Old 01-11-2004, 03:36 PM   #4 (permalink)
View dbruce's Photo Gallery
The knock sensors will retard the timing. Depending on how your car is tuned from the factory, the timing should advance or retard depending on fuel used.
For the most part, you shouldn't see any difference if you advance the timing. With computer control timing is for the most part out of your hands.
dbruce is offline   Reply With Quote
Old 01-11-2004, 07:34 PM   #5 (permalink)
Nick's Avatar
i think up to 7 degrees should be alright, if it runs like crap, bring it down to 3-5
-Nick
Old 01-11-2004, 08:05 PM   #6 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
I wouldn't advance it more than 4 degrees on a stock motor.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 01-12-2004, 07:16 AM   #7 (permalink)
I read on another forum a guy with the 1MZ got his timing advanced but I think it was more near 8 degrees, so I would probably go with 7 degrees or somewhere around there, however, judgin by 5SFTE's post I may not even bother at all.
4 degrees isn't really worth it is it?
Eibach Springs
Bilstein Struts
TRD Quick Shifter
Ripp Mods Header
K&N Air Filter
if < 1 ohm
