Steering Wheel Pulsation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2004, 03:19 AM   #1 (permalink)
Bookin' it...
View yotatechie04's Photo Gallery
Question Steering Wheel Pulsation
When I'm driving down the road, at about 25 - 30 m.p.h. the steering wheel pulsates and has this back and forth moving going on. Anyone know what causes this, and what can be done to fix this? (It seems like I'm having way too many suspension problems.)
yotatechie04 is offline   Reply With Quote
Old 01-12-2004, 11:03 AM   #2 (permalink)
Mr. A. Wong
grapefury's Avatar
View grapefury's Photo Gallery
check your tires, pressure/alignment etc
grapefury is offline   Reply With Quote
Old 01-12-2004, 11:04 AM   #3 (permalink)
Mr. A. Wong
grapefury's Avatar
it happened to me also right after a shop did some tire work, but the problem went away by itself strangely heh
Old 01-12-2004, 11:05 AM   #4 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
tire balancing/tire out of round
-Nick
Nick is offline   Reply With Quote
Old 01-12-2004, 11:20 AM   #5 (permalink)
There's a post button?
View Yanahdi's Photo Gallery
Get your balance checked. If its not your tires then your rims might be out of round (maybe slightly bent). I've had both of these problems before.
Alignment will cause the car to pull to the left or right. Unbalanced wheels will make the steering wheel shimmy back and forth that will get worse the faster you go.
1999 Solara SE (5S-FE)
Eibach Springs
Bilstein Struts
Whiteline Swaybars (Front and Rear)
TRD Quick Shifter
A'pexi World Sport Cat-back exhaust
Ripp Mods Header
K&N Air Filter
RESISTANCE IS FUTILE
if < 1 ohm
Yanahdi is offline   Reply With Quote
Old 01-12-2004, 12:52 PM   #6 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
Yeah Get a tire balance. Around here they do it for $4 dollars a wheel. Real cheap and that might get rid of your problem.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 01-13-2004, 02:05 AM   #7 (permalink)
View Camdaddy's Photo Gallery
Unbalanced tires for or uneven wear patterns on tires cause by incorrect alignment angles....4 bucks to aligns thats amazing...I work at Sears Auto Center and they charge 11 bucks a tire....hehe...
" The Replacement for Displacement is Technology. "
Camdaddy is offline   Reply With Quote
Old 01-14-2004, 12:48 AM   #8 (permalink)
MOUTH SLAP!
I forgot to mention that its 4 dollars at the costco tire center.
I dont know how much it costs outside the Costco tire center. But all I know is that I paid 4 dollars a tire over there. Try your closest Costco. And if your not a member, go with a friend.
Old 01-31-2004, 10:43 AM   #9 (permalink)
Bookin' it...
Thanks for all of your help guys, I figured out that it was the tire pressure, it was really off. I had about 12 pounds in the pass. front tire, and about 20 pounds in the driver side. After leveling them out, the pulsating stopped.
