low idle after oil change and tranny flush - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2004, 06:12 PM   #1 (permalink)
View yosh's Photo Gallery
I recently been experiencing a low idle at around 600-800 rpm when normally it would be around 1000. I just had an oil change and tranny flush at 33,000 miles and I was wondering is this normal?
2000 Camry LE V6
TRD Supercharged
yosh is offline   Reply With Quote
Old 01-12-2004, 06:27 PM   #2 (permalink)
View Nico's Photo Gallery
I don't think there could be a link really.
Are you sure you didn't mess up with anything else (with the throttle body for instance) ? Did you change spark plugs as well ?
You mean normal idle at 1000 rpm, is that when engine is cold I guess ? It might be that your throttle body needs to be cleaned.
It could be a number of things in fact ...
Nico
Nico is offline   Reply With Quote
Old 01-12-2004, 06:36 PM   #3 (permalink)
This is the only thing that was changed in my car. It is possible that I only noticed it after the change and flush but I doubt it.
2000 Camry LE V6
TRD Supercharged
Old 01-12-2004, 07:34 PM   #4 (permalink)
Zzzz...Caught ya Sleepin'
View TRDCAMRY's Photo Gallery
Normal idle should be 750-800 rpm's.
TOYOTAS RULE!!!!!!!!!!!
1995 Toyota Camry TRD
http://www.cardomain.com/id/kaystrd
TRDCAMRY is offline   Reply With Quote
Old 01-12-2004, 09:39 PM   #5 (permalink)
Its still a Camry.
Camry_rider's Avatar
View Camry_rider's Photo Gallery
Took the words from my mouth, if anything...you car is running normal. I wouldn't worry about it. When you car idles above 1000k rpms...then you worry.
1991 Lexus ES250, 2006 Nissan Altima 3.5 SE
Camry_rider is offline   Reply With Quote
Old 01-13-2004, 01:53 AM   #6 (permalink)
well anyway it's returned to 1k
2000 Camry LE V6
TRD Supercharged
