NEED HELP! starting problem
"92 Cam 4cyl" i started the car up this morning and after work this afternoon and it started up fine. I get home and put the floorboard carpet back in the car. I didn't notice anything getting messed with under the dash area when i put the carpet back in but i go to start the car up and it starts up and turns over pretty normally, but then dies about 2-3 seconds later. I then saw that one of the two cables i have going to the starter had come out of the battery terminal. I reconnect it and the car seemed to start up fine. I may have stopped it too quickly but i thought it kept going like normal and it turned over great. I go and start it up again a minute later and it's doing the same thing. The alternator connections look fine the distributor and coil wires should be fine, and the intake is normal. What could be wrong? I really need this car right now. any help would be appreciated.
Drives: '03 Tacoma 4cyl 2X4
