SRS Warning Light ON
Hey guys, I have a 96 Camry LE V6 and the SRS warning light poped up after I replaced the CV HalfShalf. I don't know what I've done wrong can you guys give me some inputs. It was my first time doing the axle so, not sure what steps I've need to go through. One curious Idea occured after the light came on is that I did not disconnect the battery, I don't know if that would caused the problem. Also, when I take the axle out again and turned on the ignition key, the Warning light is off, and the horn work( Horn does not work when the CV HalfShalf is installed).
Please give me some advice on what I should do to fix the problem. I don't know If I've messesd up any of the sensors, If I did, which sensor could I have possibly messed up?
Thank You,
PL
