Driver Side Door Lock Jam...Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2004, 05:05 PM   #1 (permalink)
View questions's Photo Gallery
Unhappy Driver Side Door Lock Jam...Help!
I have a 1990 Toyota Camry wagon. Today, I got in my car and locked the doors as always. When I tried to get out, i pressed the unlock button and all my other doors would unlock except for the driver's side. It would try and lift up a little bit, but not enough to unlock. I also can not pull it up to unlock it. From the outside, I can't unlock this door either. Does anyone know what to do with this? Is there some simple remedy I can try like WD-40, so I don't have to go to the mechanic? Note: It's extremely cold here, windchill below zero and snowing, could that have anything to do with my problem?
Thanks,
Kira
questions is offline   Reply With Quote
Old 01-15-2004, 05:11 PM   #2 (permalink)
Cello8619's Avatar
View Cello8619's Photo Gallery
I have a 96 camry and my locks would freeze every morning, try getting hot water and pouring it on the lock, that should make it work, then i put a silicone lubricate in since it won't freeze and after that i put alittle bit of wd-40 to keep every thing lubricated. My locks havent frozen since.
1996 Green Camry DX Coupe with a 5 speed
Cam's Online Home
Cello8619 is offline   Reply With Quote
Old 01-15-2004, 05:20 PM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
spray in some lock de icer, or some winshield washer fluid, then maybe a tiny bit of wd40 and work it though, hopefully that won't freeze too
-Nick
Nick is offline   Reply With Quote
Old 01-15-2004, 07:11 PM   #4 (permalink)
Cello8619's Avatar
Just to let you know the DeIcer stuff works better as a preventive measure.
Cam's Online Home
Old 01-15-2004, 10:00 PM   #5 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
I had the same problem with my rear left lock. Unfortunetly the lock stopped working while it was in the "Locked" position. That sucked because in order for me to take the door off, I have to have access to the screws on the side of the door.
I had to take the backseat out, BREAK the lock from the side. Then open the door and change the lock motor. It sucked. You can get it fixed for around 75 bux including new motor.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 01-15-2004, 10:31 PM   #6 (permalink)
FloridaPino
eviltwin67's Avatar
View eviltwin67's Photo Gallery
That used to happen to me when we lived in Chicago. I just sprayed WD-40 on the key and turned it several times in the lock as well as used the small straw to spray some in the lock mechanism on the side of the door. I sprayed it on the metal part of the door pillar too. WD-40 is supposed to help "displace" moisture, so this seemed to help prevent any further freezing. I also bought a disposable lighter to warm the key up a little before inserting it the lock, but I didn't have to use it after the WD-40.
96 V6
Amsoil foam filter
Upgraded headlight Harness w/ Sylvania Cool Blue
APS 996A Remote Start Alarm
eviltwin67 is offline   Reply With Quote
