Oil Pan Leaks
I needed to remove and replace the oil pan to install a new timing belt. That all worked fine, but I have had a leak in the pan seal since. I finally removed it again, cleaned it all off, and reapplied the Toyota sealant and let it sit for over a day. Unfortunately, it is still leaking, but in a different place. What am I doing wrong? Do I need to get a new pan and try again? Could it be bent, etc.? Or do I need to take it to a garage?
The car is a 4cyl 2000 Camry with about 143K miles on it.
Thanks. Wayne Arny, Galesville, MD
